bass management
bnrimal
I have a denon 1803 and the RM 6700/303 and just got a
Pioneer DVD-A / SACD player that has a crossover at 80 Hz.
I primarily listen to music, what is the ideal set up?
Post edited by bnrimal on
The manual for your system reads as follows:
FRONT AND REAR SPEAKERSRM2350
Overall frequency response:
95Hz24kHz
-3dB limits:
130Hz20kHz
Seeing the crossover at 80hz means your trying going to lose the sound between 80hz and 130hz. Set your crossover at 150 or 200hz. -
What does it mean with the overall frequency response and
-3db limit? -
Frank,
If he goes to 200 Hz he'll lose the top-end bass. The 303 is gone at 160 Hz...
150 Hz is the only choice.More later,
Tour...
Vox Copuli
