Multiple amps - one pair of speakers
Polk-it-up
I have found that A/V receivers and good stereo sound don't necessarily mix. Therefore, I have a separate A/V receiver and integrated stereo amp. Unfortunately, I only have one set of speakers which requires that I swap cabling between the A/V receiver and the stereo amp depending on if I am watching a movie or listening to music. Has anyone come across an amp selector switch? I've seen plenty of speaker selector switches.
Post edited by Polk-it-up on
Check out the Niles Audio DPS-1. It costs about $50 - $60.I have found that A/V receivers and good stereo sound don't necessarily mix.
Not sure everyone would agree. What kind of receiver do you have?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Thanks for the info. Just what I was looking for. Just wished it accepted banana plugs. I really should qualify my statment about great two channel sound from an AVR. In my case, it's absolutely true because my AVR is a low end Sony SDR695. I now use a NADC370 for two channel and the difference is amazing. How I ended up with the NAD was I went to my local shop (www.audioperfection.com) looking for a replacment for the Sony AVR. Anyways, it was the saleperson who convinced me that if I wanted the best two channel sound to go separte. I asked him how the two channel sound of the NAD T773 AVR compared to the C370 and he basically said manufactures always must make some compromises in stuffing a preamp, amp, tuner etc in a single cabinet so the C370 would sound better. How much better? I won't know for a few months until I can affor to buy the NAD T773 to replace the Sony. Are there AVRs with great stereo? You bet. It all just depends on your budget. But I bet if you asked some of the high-end manufacturers such as Krell or B&K if you would get "better" two channel sound from their separates versus their AVRs, they would say yes.
I think you are comparing apples to oranges here. AVRs can be plenty capable of reproducing good stereo sound. I don't think the two amps you have there are very comparable. Good luck on your amp switch search.
Yeah, Ive been looking for an amp selector for a long time, especially one that could accept banana plugs, but so far, this is the only one I've found. I even tried to find out some info on where you could DIY. Doesn't seem like such a high tech project.
My issue has been my reluctance to add a device between my amp/receiver and my speakers. I hope it won't negatively affect the sound.
Let us know if you run across a better one.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Also, check out this old thread..
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=5368&highlight=Niles+DPS1HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
