TV Volume problem..
Toolfan66
Toolfan66 Posts: 18,284
We have an older Samsung Plasma TV, when we turn the TV on the volume is at 74 just screaming at you, get it turned down, shut it off and back on same thing..
I have looked at all settings, unplugged it for a few, same thing. It’s very annoying..
The TV still has a fantastic picture as is fine except the volume issue..
Any ideas???
    pitdogg2 Posts: 27,549
    Yep turn off the TV speakers and use a reciever and bookshelf speakers. Problem solved.
  • rooftop59
    rooftop59 Posts: 8,120
    Or a magnify mini. Used go for less than a bill on eBay.
    Game Room 5.1.4:
    Bedroom 2.1
  • Jimbo18
    Jimbo18 Posts: 2,351
    Toolfan66 wrote: »
    Any ideas???
    Is there a setting where you can return the audio to defaults? Don't know what that would be, but it should be a lot lower.
    msg Posts: 10,532
    Is this a smart tv?
    (Don't answer that. If it knew what was good for it...)
    Wondering whether there's been a firmware update to address this.
    Otherwise, have to say, factory reset and then lastly, yeah, like the guys say, disable the speakers and use out to receiver or sound bar.
    Is there a headphone jack? Wonder if a dummy plug would disable the speakers.
