Alternate to CS400.
gmcman
gmcman Posts: 1,887
I'm going to setup the guest room/ kids game room, and will be using my RT800's for the mains. I can make the CS400 work, but curious if the CSi A6 would still be a good timbre match.
Reason is, trying to find a decent tv stand with a 9" opening is proving difficult for the middle shelf. Something along the lines of a Bell'O Triple play for comparison.
I could use it on the top shelf, but had other plans. Not a deal breaker to use the 400 but the A6 is a slimmer fit.
  • FestYboy
    FestYboy Posts: 3,861
    CS250?
  • gmcman
    gmcman Posts: 1,887
    The 250 uses I believe the 5 1/4" drivers, the 400 uses the same 6 1/2" as the RT800.
  • Jimbo18
    Jimbo18 Posts: 2,351
    Also, CS245 or CS300, not the same size mid but the tweeters will timbre match.
  • FestYboy
    Or, if you want the CC to more than keep up with the RT 800, go CS350. Only issue there is it's rather wide.
  • rooftop59
    rooftop59 Posts: 8,120
    edited June 2018
    I don't think it will be a problem to go with an RTi5 or RTi A6. No, they are not prefectly matched, but there are similar in timbre and only voiced slightly differently (a little more forward with about a 5db boost at 5kh). They are great centers for HT, and if you have a receiver with a decent calibration program I doubt you will notice any discrepancy...
    We always say biggest, baddest center you can go with...
    Game Room 5.1.4:
    Bedroom 2.1
  • mpitogo
    mpitogo Posts: 523
    I say go with your ears and the better sounding center. In one of the two HT I have, I am using a Martin Logan Motion 60XT as the center and its not matched to the LSi25 LR other than the nice gloss black finish but sounds 100x better than the LSiC. (I read the LSiC is better with an aftermarket crossover mod but at what gain?) The receiver with Audyssey multi xt32 handles the rest, level matching and equalization curves.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
