Using preamp 2 outputs for 2 pairs of speakers
I have a thread in "electronics" that perhaps I should have posted here. I think the normal use of the 2 outputs on a preamp are for biamping? Can they also be used to run 2 pairs of speakers(1 pair would be indoor and 1 pair outdoor) with 2 amps? If I wanted to only run say the outdoor speakers, I just would not turn on the "indoor amp"? Would this cause any damage?
Yep, my name really is Bob.
Rogue Audio Conus Magnum iii Dark, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub.
  • mlistens03
    mlistens03 Posts: 2,767
    muncybob wrote: »
    It would make no difference to the preamp, it is designed to use both outputs. I don’t know if it would cause damage to the amp or pre to have the pre plugged in and running into the amp, which is turned off. It could cause damage, or it could do nothing. I don’t know, and I’m looking forward to the answers of others (a question I’ve wondered about myself :wink: )
    edited May 2018
    You'd be fine.....as long as you can manually switch between the 2 different outputs and are running two amps I see no reason why it wouldn't work.
    Some pre amps have dual outputs for running subs with and both are active all the time. If your able to switch between outputs on the front of the pre, you should be peachy.
    Of course, the other option is....just use a speaker selector switch.
  • mlistens03
    tonyb wrote: »
    Yes, but that’s no fun.
  • daddyjt
    daddyjt Posts: 3,269
    No issue whatsoever.
    Gain matching would be the only possible wrinkle. I would assume if you pick up another Parasound amp, the gains would be similar (though TBH I don’t have a lot of experience with the brand). That would only leave speaker efficiency as the determining factor for equal sound output between the two, assuming that’s a concern.
    ― Aleksandr Solzhenitsyn
  • muncybob
    muncybob Posts: 3,354
    So it makes no difference if the pre is tubed? I don't have a switch to choose the output so I'm relying on not turning on the amp to not engage a pair of speakers.
    A speaker switch would be my route to take normally but I want to upgrade my "indoor" amp from the HCA1000 and use the latter for the outdoor speakers. I could just get a Parasound 2250 and sell the 1000 but it may be cheaper and less hassle to just buy another amp such as the HCA1500? Looking for more current to the indoor speakers at less than $800.
    EndersShadow Posts: 17,765
    No difference. The only keep (which you identified) is that the signal will be going to both amps 24/7, so you'd need to turn OFF the amp you DONT want on.
    Also there "might" be differences in how LOUD each set it due to difference in sensitivity of the speakers as I'm assuming you'd be using different brand speakers in each room.
    If the amps you have provide a gain knob, then you could adjust till the levels are even and be fine (if you even care)
    edited May 2018
    muncybob wrote: »
    Makes no difference if the pre is tubed. However, it would if that other set of outputs was dedicated to a subwoofer output. Seems to me, a speaker selector switch would be cheaper than buying another amp..I use something like this but for 3 sets of speakers.
    https://www.amazon.com/Speaker-Selector-Switcher-Control-Commercial/dp/B00UZ86M0E/ref=sr_1_37?ie=UTF8&qid=1526998891&sr=8-37&keywords=speaker+selector+switch
    That way, you can benefit from it accepting up to 12ga. wire, which is a plus and not all do, and individual volume control, which some do not have.
  • muncybob
    Tony, that's a nice selector for sure. I may get this to use with the avr which runs my front deck speakers along with the movie room speakers. Currently have an old Niles switch that works fine but it won't take nanners.
    The original thought was get more current to my 2B's for better low volume listening and I figured why not also include the back deck speakers too(which are currently also connected to that Niles switch off the avr) so I can enjoy my records while chillaxing. I'm hoping upgrading the HCA1000 to an amp with more current will give me better low volume sound? Not worried about any difference in gain as I doubt I will ever run all four speakers(2B's and back deck spkrs) at the same time.
    So, knowing another amp will be in the works and a budget of $800 max...any suggestions? As I stated previously, I was leaning toward the Parasound 2250 as the HCA1000 has good synergy with the tubed pre but now that I know I can use 2 amps with no problems the door opens up a bit. Keep in mind I'm really needing an amp that sounds good at low volume and of course even better at higher db.
  • pongshi
    pongshi Posts: 376
    I had a similar issue since I have 2 sets of speakers set up in my living room. Depending on where I sit, I select either A or B set. I used a Niles Speaker selector. I don't remember the model. It was one of their more expensive units and it was for 4 speakers. It worked well, but I later bought a Parasound 250 V2 which I am still using. It has an A/B switch. It is a shame more amps don't have this feature. The 2250 v2 may not get as many accolades as their more expensive amps, but I am very pleased with mine.
    Living Room
    Parasound Model 2250v2 amplifier
    Parasound P5 preamp
    Turntable 1 - Technics SL-1210Mk2 turntable with Shure V-15 Type III cartridge
    Turntable 2 - Dual 1229 turntable, Dual AS-12 45 RPM stacker, Shure V-15 Type III cartridge
    Schiit Mani Phono Preamp for Turntable 2
    Oppo UDP-205 CD/SACD USB and FLAC duties
    Technics RS-1500US reel to reel
    Polk SDA SRS (2nd Gen) fully modded
  • muncybob
    The 2250 is rated at 45 amps peak, the HCA1000 at 35. I wonder if apprx 30% more current will provide me the improvement I'm after?
