Refinish oak table top...what to use?
Our kitchen table has a golden oak type of stain on it and what appears to be polyurethane finish(it's glossy). I plan to take it down to bare wood(or as close as I can get it) and want a finish on it that is food grade and not shiny. So it will match the legs(not doing anything with them, they are in good condition) I guess I'll need to apply some sort of golden oak stain...but what should I finish it with...oil of some type?
Yep, my name really is Bob.
    pitdogg2 Posts: 27,206
    Satin polyurethane will have no gloss
  • Mikey081057
    Mikey081057 Posts: 7,127
    You need to get it down to bare bare wood ... the better the prep the better the new finish will be. You can apply a stain. A poly can you give you durability since it is a table top. Lacquer looks the best but can have durability issues. it is oak and oak is very labor intensive. There is nothing easy about a good finish.
    @F1nut can give you the best advise.
    Garage | Polk Monitor 5B's
    F1nut Posts: 51,927
    Just because the sheen is gloss does not mean the finish is polyurethane.
    You will never match the color of the top to the legs unless you have a pro do it.
    Any cured clear coat finish is food safe.
    Oil is a horrible choice for a kitchen table.
    Whatever finish is on there now will have to be completely removed (not as close as you can get it) before applying a new one.
    Your best bet for a durable finish would be conversion varnish, full catalyzed lacquer or polyurethane. The first two must be sprayed and contain toxic stuff, which helps the curing, but becomes non-toxic once fully cured in a matter of days. You must wear a respirator with special filters when spraying either otherwise you'll have the worst headache you'll ever know.
  • Mikey081057
    Jessie what would hold up best.... resist watermarks and stuff that could happen to a kitchen table?
    F1nut Posts: 51,927
    No i.
    Conversion varnish, which isn't actually a varnish. Very tough stuff. It should be noted though that the tougher the finish the harder it is to repair. Polyester is even tougher, it's what you see on pianos, but I wouldn't recommend it for a kitchen table. Extremely difficult to repair.
  • maxward
    maxward Posts: 1,711
    @F1nut, what would you recommend for the average diyer? It looks like conversion varnish is best left to professionals.
    F1nut Posts: 51,927
    If you don't have spray equipment that pretty much leaves a wiping or brush finish. Probably the best choice then would be a wiping poly, but the coats are thin, so you need a minimum of 3 and for a kitchen table I think at least 5 would be a good idea.
  • maxward
    Thanks. I never tried wiping poly, so may give it a try once the temperature gets up.
  • muncybob
    muncybob Posts: 3,262
    I was thinking poly also, was thinking diluting an oil poly 3:1 w/mineral spirits and apply the thinned coat with natural hair brush. Any advantage to wiping poly over this?
    F1nut Posts: 51,927
    Yes, you won't end up with brush marks or drips.
  • Airplay355
    Airplay355 Posts: 4,298
    Is tung oil that you commonly see in stores really just a form of varnish? I used that on a table and it dried hard and shiny. I used it on rosewood. Seems durable enough? It’s my first attempt though.
    F1nut Posts: 51,927
    Yes, not much tung oil in them.
