Why are so many things packaged in next to impossible to open materials?
Is the chainsaw lobby that strong? Even cardboard/bubble packs need the "jaws of life" to open, let alone the pure bubble packed stuff. Hell you can loose a limb if you are ot careful opening those! While I am at it, I hate "jewel" cd cases. "jewel"? how bout "junk dirt ball garbage" cases that always bust? Some "jewel". Don't get me started on those infernal stickers! It's a conspiracy I tell ya, just wait you will see. They will package all food like this just to kill off the weak and arthritic.
  • george daniel
    george daniel Posts: 12,096
    Did I ship you something? :)
  • shawn474
    shawn474 Posts: 3,052
    I am convinced that companies package this way so that it is next to impossible to be able to return things. The plastic packages that are heat sealed on the edges are like razor blades when it tears!!!
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
    gudnoyez Posts: 8,159
    edited April 2018
    Troubles opening up the new Porcupine Tree CD Bruce? Anyways here is my combatant when it comes to getting to business and playing tunes once you get that brand spanking new CD
    1. Smith & Wesson the sight adjustment gently slide in and put the small adjustment in the top corner part of the shrink wrap pull up and your in business remove that wrap.
    2. Grow one of your fingernails out like a 70s disco king that had a reason for one long fingernail and start working on the frigging tape or whatever it is to prevent you from getting to the tunes. If your not into one long fingernail, use the Smith & Wesson sight adjustment.
    3. A bottle of Goo Gone or Power Plus industrial strength or similar product, I use these and a cotton ball, saturated in the stuff to remove that %!****% residue.
    4. Have a couple of spare Jewel Cases around because it's guaranteed if Amazon or Best Buy shipped it the ^^%%^#@mn jewel case will be cracked.
    I hope this helps you for further on down the road on your new music (CD) purchases, remember Smith and Wesson is your friend, I have used that tool to open more ^@!>_/$%÷mn Jewel Cases than I have adjusting sights on my guns.
  • rpf65
    rpf65 Posts: 2,127
    afterburnt wrote: »
    They created the packaging to specifically upset you.
    Countless dollars were spent researching you are in particular, and it was determined after 5 years of research, conferences, and psychological profiles that you wouldn't consider investing in a box cutter or utility knife to open the packaging material.
    They have already recouped their investment dollars by investing in band aids.
  • verb
    verb Posts: 10,176
    Why @gudnoyez are you a Smith fan? :smile:
  • afterburnt
    afterburnt Posts: 7,892
    gudnoyez wrote: »
    I can't find my sight tool. I am just gonna have to use the 586.
  • afterburnt
    edited April 2018
    rpf65 wrote: »
    afterburnt wrote: »
    I know!
    Btw box cutters go through that killer plastic like hot knives through bricks.
  • Nightfall
    Nightfall Posts: 10,084
    I have a Smith and Wesson too.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Joey_V
    Joey_V Posts: 8,600
    I always think partially it is because they don’t want you to return it.
  • afterburnt
    Joey_V wrote: »
    I bet they just throw returns away because it's cheaper than repackaging it.
  • afterburnt
    No but if you do can you include a complimentary secret decoder ring and fire axe combo?
  • afterburnt
    @gudnoyez Steve I used all of my goo gone in the laundry
    F1nut Posts: 51,700
    afterburnt wrote: »
    That's sig material.......LOL
    VR3 Posts: 29,400
    Take a drill, Phillips head bit, spin it at full speed into the plastic until you go through then pull the drill through the plastic, cuts like butter :)
  • rpf65
    rpf65 Posts: 2,127
    VR3 wrote: »
    You don't have a cutting torch?
  • kharp1
    kharp1 Posts: 3,453
    "Easy Open Package" is the biggest lie being perpetuated!
    pitdogg2 Posts: 26,962
    kharp1 wrote: »
    Tell that to my ex-wife.....
  • delkal
    delkal Posts: 764
    It is a conspiracy. The can opener manufacturers were going under since not many things come in regular cans anymore............Only $17 on Amazon.
    mhardy6647 Posts: 34,935
    There used to be this company in New Zealand (or maybe Australia -- never can keep those two straight) called Tullen that made these little snipper/shear things.
    They were for general purpose/kitchen use and are perfect for things like "clamshell" packaging.
    The company went out of business (maybe family owned) -- and (rumour has it) someone bought the "technology" and shelved it. Sort of like GM and the 100 mpg carburetor, don't you know? ;)
    So, if you ever find a pair of Tullen snips at a yard sale or something -- buy 'em.
  • mlistens03
    mlistens03 Posts: 2,767
    kharp1 wrote: »
    Other than “I have read through and agree to the terms and conditions,” of course.
    The packaging y'all are disparaging -- I think -- has a very simple explanation.
    If one opens it, it is pretty darned obvious that it's been opened :|
    I believe this is to minimize the chance that a consumer could buy something, open it, use it, and then return it to a store as new, unused, unopened, NIB etc.
    That's my belief.
    tonyb Posts: 33,068
    Tape an M80 to it...or drag it behind the car until the wrapper wears off.
    My preferred method of choice is to give it to the grandkids to open. It seems they have a knack for such things.
    Or maybe something fancy like..... scissor's
    Tullens are to scissors as Pass Audio Labs is to Soundesign.
    Would I lie to you?
