Where can I find NEW parts for Polk SDA 1.2
Need Polk vintage information from some vintage Polk Vintage experts!
I just bought a pair of Polk Audio's SDA-SRS 1.2, I was wondering where I could buy 2 new 12" passive radiators for these speakers.
Also, I see where I can upgrade to the SL3000 series tweeters. Does anyone know if this is an official Polk tweeter? Looks like it. I just hesitate on eBay. https://www.ebay.com/itm/162248956136
Thanks ahead of time!
Travis
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Welcome to Club Polk and congrats on your new ownership of the SDA's.
    First off, you will need 15" Passive Radiators, which are mostly impossible to find as they are not offered new from Polk Audio. You need to do a "Saved Search" on eBay, just in case a couple might show up for sale. Depending on what kind of damage the PR's suffer, they may possibly be repaired. If all else fails, you might try to pick up a "rough" pair of SRS 2's, as in cheap, and utilize the PR's from them.
    The good news is that you can buy replacement Tweeters (RDO-198) directly from Polk. Tell them you are a Club Polk member and receive a little discount, the cost will be less than the eBay add.
    Good Luck!
  • Moose68Bash
    Moose68Bash Posts: 3,843
    If your 1.2s are not TLs, you will need RDO-194 tweeters for "drop-in" replacement of the tweeters.
    If your 1.2s are 1.2tls, then the tweeter on Ebay, an RDO-198, is a "drop-in" replacement.
    If they are 1.2s, then you should consider doing the full upgrade to 1.2tl, which requires crossover mods that you may be able to do yourself. If you can't there are a couple of guys on the Forum who can do a great job for you at reasonable prices.
    Welcome to the Forum -- and to the Rabbit Hole.
    PS: You might want to hang on to your wallet.
  • 250GTLusso
    250GTLusso Posts: 163
    @chatra , can you post a picture of the damaged PRs? You'd be surprised at what this group can restore. Give us a shot at it. I'd hate to see a restorable 15" PR go to the junk pile, as they are unobtainable.
    HT
    Adcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).
    2 Channel (Living Room)
    Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.
    2 Channel (Office)
    Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).
    2 Channel (Garage)
    Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
  • Mike Reeter
    Yes, if Stock 1.2’s, the RDO-194 is the correct tweet. My bad! You can buy them directly from Polk as well.
  • Randnich
    Randnich Posts: 17
    Love this site. Been away a while, finally going to rebuild my 1.2tl's and needed 6 tweeters, didnt even have to ask thanks to this thread. Just wanted to leave a thank you!
  • Just got my hands on a pair of SDA's. I do not know their history, speaker plate says 1 is a 1.2 the other is a 1.2TL. I'm amazed at how they sound. Top of 1.2 is damaged.8p0lqbksjzwu.jpg
    What would be the best way to replace the top?
    If I upgrade the 1.2 to TL, would the other TL need refreshed?
    Looking forward to this journey.
    Thank you
  • dkfreebird
    dkfreebird Posts: 1,186
    If that is a pic of the one labeled 1.2 it is probably a tl also.It has the sl3000 tweeter in it.Start you a new thread with more pics and we can help you spend your money on upgrades. :)
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • Mike Reeter
    Archiedog wrote: »
    Thank you
    Remove the 2 top Mid-Drivers from the cabinet ( make a note of the wiring) and then reach up into the top of the cabinet. You will find 4 taps that fasten the Tops to the cabinet. I think the taps (nuts) are either a 3/8 or 7/16.
  • verb
    verb Posts: 10,176
    Several ways to go here. A lot of Polkies replace em. If that is the only damage, that's a pretty easy re-veneer job. If you have tools, you can cut a replacement MDF board to size. Some folks use real wood replacements, especially if you go for all 4 endcaps.
    Use contact cement to attach the veneer.
    Veneer is pretty easy to cut/sand since it's so thin. Stain/finish to match.
  • ptrooper
    ptrooper Posts: 501
    What was the out come in the end,,,,replaced or repaired?
    chatra wrote: »
    Travis
    pitdogg2 Posts: 27,338
    edited August 2020
    1.2 srs or srs or just 1.2 none take a 12" radiator. If fact I've never seen more than 1-15" passive ever sold on ebay. I've had a search set up to message me if any show up.... Still waiting 6yrs later
