Wooden end caps on SDA-1Cs
Oldreliable7m
Hey Guys I need some help on my SDA's The wooden end caps are basically trash and i need help or if i can pay somebody to do it for me..... like my Monitor 7s these need some help but there alot better than the speakers they have replaced. I would like to go with a complete wood look instead of the speaker grill fabric on the sides then wooden end caps if there's anybody out there that can help please let me know
Welcome to CP! I'm in the middle of doing the same.
http://forum.polkaudio.com/discussion/179960/another-1c-upgrade-path/p1Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Thanks verb those a some really nice sda1s you have i wish mine where the same my wooden end caps are completely rotted i got three blow drivers two midbass driver in the right channel and one blown tweeter in the left but im willing to do what ever it takes to make them look amazing again
Oldreliable7m wrote: »Thanks verb those a some really nice sda1s you have i wish mine where the same my wooden end caps are completely rotted i got three blow drivers two midbass driver in the right channel and one blown tweeter in the left but im willing to do what ever it takes to make them look amazing again
You came to the right place! Lot's of Polkies here will help you on your journey!
Now if I can just get off my arse and finish em! Oh yeah I have another pair minty 1C's that keeps distracting me!
Thanks i Truly love the sound of these sda's im hoping once i upgrade to the rd0-194 tweeter my monitor 7s will be the perfect partner to these sda's -
Oldreliable7m wrote: »Hey Guys I need some help on my SDA's The wooden end caps are basically trash and i need help or if i can pay somebody to do it for me..... like my Monitor 7s these need some help but there alot better than the speakers they have replaced. I would like to go with a complete wood look instead of the speaker grill fabric on the sides then wooden end caps if there's anybody out there that can help please let me know
Every SDA that someone has replaced the cloth sides with wood looks like crap. It simply doesn't work. What does work is to get rid of the end caps and veneer the entire cabinet, which more or less turns them into a Studio version. One guy did his 3.1TL's in cherry, looked fantastic. If that's your plan, go for it. However, you can't use the original grill, so if you want grills new ones will have to be made.Political Correctness'.........defined
President of Club Polk -
Aesthetics by definition are subjective. It all depends on the quality of execution. There are many examples here on CP and elsewhere of wood sided replacements that look great!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
They look like CRAP, every single one of them. The reason being are the disjointed wood surfaces. There's nothing harmonious about it.Political Correctness'.........defined
You're repeating yourself!
Yep and on this matter I'll continue to do so.Political Correctness'.........defined
I'm looking forward to your appraisal on my Zebrawood Side panels!
Thanks for your comment F1nut i guess i wont go all wood then.... if im making the grills might as well make new cloth sides i'm thinking dark cherry tops like almost a dark blood red or even a dark walnut. also how do i accomplish getting rid of that dry glue on the black vinyl without damaging the vinyl
As far as I know there is no way to completely remove the original adhesive without some damage to the vinyl. Thing is though, you don't have to remove all of it. Just scrape and/or chisel off the excess.Political Correctness'.........defined
Look up a product called Rapid Remover, we use it for wrapping and it works really well. Not cheap, but a little goes a long way.
Look up a product called Rapid RemovHer, we use it for wrapping and it works really well. Not cheap, but a little goes a long way.
Good to know next time my wife complains about my music...TFS
Thank you All for your help I’m really looking forward with these two projects I got going if I need any help I will let the awesome Polk forum members know I’ll also will keep you guys posted
I have read that Rapid Remover is an adhesive remover, specifically for removing vinyl wrapping adhesives on cars and trucks, and it works without causing damage to most painted or bare metal surfaces.
But will it damage the vinyl on the speaker?HTAdcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).2 Channel (Living Room)Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.2 Channel (Office)Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).2 Channel (Garage)Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut). -
It will not. But then again that's graphic vinyl, as opposed to the architectural vinyl that's on the cabinet. At most, I suspect it may soften it a bit, but that's easily cleaned up. Discretionary application is advised after the bulk is flaked off.
We are dealing with 30 year old material. -
@FestYboy , thanks for that feedback!HTAdcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).2 Channel (Living Room)Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.2 Channel (Office)Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).2 Channel (Garage)Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
