CS1000p Center Channel Speaker (Black) to match SDA Mains
LOCAL PICK-UP ONLY IN SOUTHAVEN, MISSISSIPPI. $400 Firm. Very good condition. Only noticeable defect is a small hole in grill cloth near top center of speaker. One of the 8 posts on rear of grill assembly that hold grill to cabinet is missing. 2 posts have been glued back in place. Causes no problems, grill mounts tight to face as it should. Some rubber missing from rear baffle. Does not effect sound. Like that when I purchased speaker. Shows in photo. Rubber feet have been screwed to base. Photo copy of manual included. Factory speaker terminal jumpers not included. (Will include if I find them!) 12 gauge jumpers with spade lugs included. Disconnected from system so no tryouts. Sorry. Worked as it should when removed from system a few days ago. As 2nd owner I purchased this 12 years ago and doubt if I used it for 20 hours. Will list here for about a week before going on eBay.
FX1000 Surround Speakers to match SDA mains also listed for sale here at same time. My upgraded SDA 1.2TL's (Walnut) and SVS PB12 Ultra Subwoofer (Rosewood) will be listed for sale here soon as have terminal cancer caused by Agent Orange in Vietnam per doctors. Entire system will also be listed shortly, either here or elsewhere.
ARROW BELOW POINTS TO SMALL HOLE IN GRILL CLOTH
Mains; SDA 1.2TL Silk Domes, upgraded xover, biamped w/DBX BX1 200wpc
Pre-amp: DBX CX1
Center: CS1000p Rear Surr.; f/x1000
Parasound HCA-1205A amp; Center & rear
Sub: SVS PB12-Ultra
DVD: Denon 3910
Tuner, FM: Onkyo Integra T-9090II
Cassette: Onkyo Integra TA-2090
VCRs: JVC HD4000U digital, HRS8000U SVHS
Signal Processing: DBX; 10/20 EQ, SNR-1, 120X-DS, 3BX-DS, DAV-600G Router, Onkyo EQ-35
Conditioning: Monster AVS2000, HTS5100MKII
