**good Or Bad Purchase?**
racer4551
Just bought these from audiogon,a pair of monster cable z2 bi-wire 10 ft pair for $150 shipped.Did i do good or bad at this price?Does anyone have any experience with this series of wire from monster?
*HT PRE-PRO*:Rotel rsp-1068, *AMP*:Rotel RMB 1095 *DVD PLAYER*:Denon 2200,*CD PLAYERS*,Arcam Alpha Mcd 6 disk carasel,Hughes Hdtv receiver, Hughes hdvr2,*MAINS*:Polk LSI 15'S, *CENTER*:Polk LSIC, *SIDE SURROUNDS*:Polk LSIFX,*REAR SURROUND*:Polk LSI 7'S,*SUB*:SVS PB2+*.MONITOR*:Mitsubishi ws48413 hdtv,Monsterpower hts2500X2,,Sony playstation2,Harmony sst-659 remote
Post edited by racer4551 on
Nice series, solid performance, you made a good investment.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
i agree.. check out my system showcase. i use the same bi wires for my RT800i's.PolkFest 2012, who's going>?
I just hope they are long enough,i know the left one is ok but the right side is going to be close,i saw someone on ebay that is selling bulk z2 cable by the foot so i could always add to the right cable if i have too.*HT PRE-PRO*:Rotel rsp-1068, *AMP*:Rotel RMB 1095 *DVD PLAYER*:Denon 2200,*CD PLAYERS*,Arcam Alpha Mcd 6 disk carasel,Hughes Hdtv receiver, Hughes hdvr2,*MAINS*:Polk LSI 15'S, *CENTER*:Polk LSIC, *SIDE SURROUNDS*:Polk LSIFX,*REAR SURROUND*:Polk LSI 7'S,*SUB*:SVS PB2+*.MONITOR*:Mitsubishi ws48413 hdtv,Monsterpower hts2500X2,,Sony playstation2,Harmony sst-659 remote
Add to ? .... uhh no ... remake maybe ...
Depending on how it is terminated, why couldnt you add length to the bi-wire end if the terminals are the removable type?Even if they are not removable why couldnt you just remove the terminals add the required length of wire and reterminate,using of course the same wire to lengthen.The only thing that would be of question would be how to connect the two wires together,could solder them and add some nice heat shrink over the solder? Dont really want to do this but if it can be done economically and right,it would be possibility.Whata you all think?*HT PRE-PRO*:Rotel rsp-1068, *AMP*:Rotel RMB 1095 *DVD PLAYER*:Denon 2200,*CD PLAYERS*,Arcam Alpha Mcd 6 disk carasel,Hughes Hdtv receiver, Hughes hdvr2,*MAINS*:Polk LSI 15'S, *CENTER*:Polk LSIC, *SIDE SURROUNDS*:Polk LSIFX,*REAR SURROUND*:Polk LSI 7'S,*SUB*:SVS PB2+*.MONITOR*:Mitsubishi ws48413 hdtv,Monsterpower hts2500X2,,Sony playstation2,Harmony sst-659 remote
racer,
You really don't want to be adding added connections to a speaker wire run. Signal loss is a real possibility.More later,
Tour...
Vox Copuli
Yeah, it probably isnt a good thing to do the more i think about it,it was just a thought.It just sucks the way the cables have to be longer for the right side because of the equipment being located to the far left.It just makes buying cables tougher.If i end up needing a longer cable i will just move one cable to the center channel and make a new one out the bulkz2 cable.The source i found the cable from even provides the correct monster shrink tubing included in the price per foot .Then all i would need would be the termination for the ends.*HT PRE-PRO*:Rotel rsp-1068, *AMP*:Rotel RMB 1095 *DVD PLAYER*:Denon 2200,*CD PLAYERS*,Arcam Alpha Mcd 6 disk carasel,Hughes Hdtv receiver, Hughes hdvr2,*MAINS*:Polk LSI 15'S, *CENTER*:Polk LSIC, *SIDE SURROUNDS*:Polk LSIFX,*REAR SURROUND*:Polk LSI 7'S,*SUB*:SVS PB2+*.MONITOR*:Mitsubishi ws48413 hdtv,Monsterpower hts2500X2,,Sony playstation2,Harmony sst-659 remote
Great Buy! You should like the Z2. Thats the same cable I use on my system!
