Looking for replacement MW6511 for SDA 2.3
Hey guys, Looking for a 6511. Anyone got one? I know you can get allot of these new but I bought one before for a different set and it looks allot different than the originals and sticks out like a sore thumb... or a new speaker amongst a wall of classic ones to be more accurate.
Tim
  • Rrusse11
    Rrusse11 Posts: 116
    Tim,
    Keep an eye out on Ebay. You may be forced to buy a set of 4, that way it will match cosmetically. Of course the other solution is to put the grills on. {;o)
    And I can highly recommend doing what I've just done to my set of 2.3s. Hurricane nuts, rebedding the speakers, and a bit of sonic foam. Great bang for the buck!
    Cheers,
    R*2
    SDA SRS 2.3s
    Pair of Carver TFM 35s
    Carver C-1 Preamp
    CAL Icon MkII CD
    RTA 12s, need major work
  • verb
    verb Posts: 10,176
    Yep agree. You can create a search for mw6511 so that eBay will notify you as soon as one is listed. Or you can wait for Karma. I recently gave one away!
  • Is there a list somewhere of all the different 65xx's and their model number designation?
  • verb
    verb Posts: 10,176
    Start using the link below. Best portal to the world of SDA mods!
    http://forum.polkaudio.com/discussion/133384/all-the-polk-sda-upgrades-located-in-one-place/p1
  • Rrusse11 wrote: »
    Tim,
    Cheers,
    R*2
    Thanks for the info. where do I read more about that?
    Any comment about SL2000 tweeters vs the upgraded ones? Im pretty happy with these. its hard to imagine anything better. Just got these things working proper.
  • Also, I should mention Polk audio here in Canada still sells replacement SL2000s and the replacements for SL3000s for the same price
    F1nut Posts: 52,104
    prosuite wrote: »
    Rrusse11 wrote: »
    Tim,
    Cheers,
    R*2
    Yeah, they are horrible. Get the new ones.
