speaker repair?
jopython
jopython Posts: 1
edited January 2002 in Technical/Setup
I own some polk 5 1/4 but one of them is making a fuzzy noise (probably blown) is there anywhere i can send it for repairs?
Post edited by jopython on
  • TroyD
    TroyD Posts: 13,093
    edited January 2002
    if it is just a matter of replacing the driver, you can get the driver from Polk and swap it out yourself. As long as you can operate a screwdriver without injuring yourself, VERY easy.
    Troy
  • crewchief68
    crewchief68 Posts: 19
    edited January 2002
    Yes an easy repair to do yourself....don't let any 'locals' get ahold of 'em!!! Do it yourself!
    Hey TroyD, ,you seem pretty knowledable....a speaker is a speaker so to speak...eh? I was thinking of replacinging the 10" driver in my 350 with on of the new Polk GNX "car" woofers. Will this work? The gnx has an incredibly low range. Could I feed that woofer more power and get a clean response? I can't get it half-way up now before i start to get some break-up in the cone and have to back off the power. Thats with only LFE's going to the woofer and the signal output of the amp at -2. Any ideas?
  • Aaron
    Aaron Posts: 1,853
    edited January 2002
    The breakup and distortion you're experiencing is more likely due to the amp than the driver. I don't think replacing the driver would make all that much difference.
    Aaron
  • TroyD
    TroyD Posts: 13,093
    edited January 2002
    ...actually I am not. I'm just a wiseass with a lot of time on my hands. I'm not much of a techie to be honest. I agree with Aaron on this....I have never really given much thought to doing something like that though.
    Troy
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited January 2002
    Aaron is right, the amp could be clipping, causing distortion.
    As far as dropping in a Polk auto sub, contact Polk to see if it would be a good match. There are many parameters to deal with here, a speaker is not a speaker. Biggest issue being impedance, enclosure size/design, and tuning.
    Cheers,
    Russ
  • crewchief68
    edited January 2002
    Since the power for the sub comes from its own source, I assume we're talking about the Polk amp...? Am I expecting too much...? I am in kind-of a large room.....any one have any expierence with 'stereo' subs?......I have also considered getting a PSW-250 for the (rear) surrounds....Could this be too much? ....Is there ever enough?
  • ntculenuff
    ntculenuff Posts: 1,146
    edited January 2002
    NO...Just more and better:D
    i have 2 subs and i love it. One for mains and the other for LFE
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • crewchief68
    edited January 2002
    Ya know if I was a real bass freak I'd come up with some plan to use the line-outs(+2-sub outs) of my amp to feed the line level in-puts of seven subs......theres an idea.
  • danger boy
    danger boy Posts: 15,722
    edited January 2002
    How would I hook up two subs to my receiver? Right now I have one subwoofer plugged into the LFE output on the receiver running to a PSW350
    thanks
    PolkFest 2012, who's going>?
  • juice21
    juice21 Posts: 1,866
    edited January 2002
    run the other sub through the mains cable - reciever to sub to mains....
    or, i guess you could 'y' the LFE
  • ntculenuff
    edited January 2002
    i have main outs that i y'd off for one sub and the other thru the lfe.
    before this i had them both y'd out of the lfe worked good. a whole lot of bass as they were both crossed over at 80hz (lfe filter) too much for music and some movies.. reading the bass management article in the speaker specialist issue #2 prompted me to try the different wireing and it made a huge difference fuller sound.
    lfe sub x-over 70-75hz
    main sub x-over 125hz
    Speakers:
    Polk RT800i's rears
    Audio:
    Onkyo TX-NR3010
    Video:
    OPPO BDP-103 Bluray
    Directv x's 2
  • ntculenuff
    edited January 2002
    this could be fun... hey what happen to my windows ?
    i can see the next cover article for home improvement mags.
    how to open up your home to the great outdoors...purchase a but load of powered subs for your home theater and crank it up !! :D
    Speakers:
    Polk RT800i's rears
    Audio:
    Onkyo TX-NR3010
    Video:
    OPPO BDP-103 Bluray
    Directv x's 2
