cleaning speaker drivers
Airplay355
my room is pretty dusty and im noticin that theres dust goin through the grill and onto the drivers and bein the neat freak i am, i wanna clean them. now i know theres been some pretty heated discussions about this on here but im just wondering, should i just use windex? or can the chemicals in that break down the surround? should i just use water? i dont want to use anything that could cause the drivers to deteriorate
Armor ALL lol J/K hope that doesnt open a can of worms lol.
Just a slightly damp rag is all I use and does a perfectly fine job.
I would avoid chemicals.
pick up a duster once in a while too
Epson 8100
Directv HR24
WDTV
ONKYO 608
POLK RTI70 Mains
POLK CSI40 Center
POLK RTI28 Surround
HSU STF-2 -
Agree with DREW. Just a well wrung-out rag, and very gentle touch.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Yeah, what they said.
Next?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
thanks guys, i knew it was dumb but i was unsure so i had to ask lol
Far from dumb to ask, sounds pretty smart to me.
Better than just glopping *cough* some off the shelf cleaner on them, and risk doing damage or shortening the life of your speaks.
If you want to be a stickler about it, pick up some lint-free cotton pads in the beauty section, and a bottle of purified water at your local grocer. Like I said, to be a stickler, even your common house towels / rags will be contaminated to a small degree with soap / dye / fabric softener etc residue.
Cheers,
But if you can't get puified H2O and lint free cloth, then an oily rag and Armor All right?:DThere are two ways to argue with women. Both of them are wrong.
as long as u armour all them twice a day they should be fine :rolleyes:
Swiffer is great. Sometimes I like to use a can of compressed air and spray the drivers.
Maurice -
swiffers huh? never thought of that ill have to try it
Swiffer is great at cleaning speaker drivers, not to mention other components.
Somehow, I would avoid the compressed air. -
what about some old foam surrounds with dust kinda caked on?
i'd use compressed air too. that way..nothing is touching the surface. rags can leave lint particles behind. and that would look bad too.
My RT7's have dust on em.. who knows how long it's been there. things are about 20 yrs old.. and the drivers appear to be sticky to me. but i'm not about to put anything corrosive on em either.PolkFest 2012, who's going>?
You could use compressed air, just be sure to use a diffuser and just enough pressure to do the job.
I'm fond of a neat little vacuum dusting attachment with VERY soft bristles and a VERY gentle touch does well, too. -
that seems like it could work, my aunt has some old sony's that she loves and they are caked with dust...i wouldnt even want to use anything wet because it would just make mud and probably go deeper into the foam surround. ill tell her to try vacuuming them
