Anyone know where you can buy a decent AVR cooling fan for cheap?
pbc74
pbc74 Posts: 63
I'm looking for an inexpensive way to cool off my avr. It sits in a entertainment center with limited ventilation. I found one for $100 but I was wondering if anyone found a cheaper way that still does the job well.
Main system:
Fronts: Infinity Alpha 50
Center: Infinity Alpha 37c
Surrounds: Infinity Alpha 20
Receiver: Onkyo TS-XR607
Subwoofer: Pioneer S-DW1-K
Cable- Monster Cable XP
Bedroom Setup:
fronts- Polk R50
surrounds- Polk R30
center- CS1
sub- Sony 50 watt
AVR- Onkyo TSXR502
Post edited by pbc74 on
  • steveinaz
    steveinaz Posts: 19,545
    edited April 2004
    If you are a DIY'er, try some Vantech Stealth fans. Extremely quiet and good cfm rating. I used these some time ago, just stuck Radio Shack rubber feet on them and set them on my amp. BINGO! Just search "Vantech Stealth" in yahoo, you'll get about a zillion hits for places to buy them...about $8.95 each. I attached a Radio Shack 500ma/12vDC walwart to run them.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited April 2004
    I too am a fan of the Vantechs...use them for cooling around the PC...
  • pbc74
    pbc74 Posts: 63
    edited April 2004
    so once you have the vantech, all you have to do is attach feet and a power supply? I don't really consider myself a DIYer but I can figure it out if it's simple.
    Main system:
    Bedroom Setup:
    fronts- Polk R50
    surrounds- Polk R30
    center- CS1
    sub- Sony 50 watt
    AVR- Onkyo TSXR502
  • AsSiMiLaTeD
    edited April 2004
    I/m not using mine for the home audio setup...but I'd just plug into the switched outlet on the receiver so that it comes on with the receiver...
  • pbc74
    pbc74 Posts: 63
    edited April 2004
    o.k. thanks.
    Main system:
    Bedroom Setup:
    fronts- Polk R50
    surrounds- Polk R30
    center- CS1
    sub- Sony 50 watt
    AVR- Onkyo TSXR502
  • polkatese
    polkatese Posts: 6,767
    edited April 2004
    One question related to the cooling fan: does anyone have any idea on how to rig a trigger-controlled cooling fan? I am thinking of a small DIY project, consist of a vantech fan, walwart, and trigger wiring/components, to turn on/off in synch with an amp, without using a switched outlet...TIA guys!
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • steveinaz
    edited April 2004
    I don't bud, but what I did was attach the walwart to my Middle Atlantic PDU, which has an on/off switch. All of my components are plugged into the MA PDU, so when I power-up, the fans come on automatically.
    PBC74: What you'll need to do is cut off the "yellow" wire and only use the red and black wire. Splce those to the RS walwart, and BAM...12vDC ready to go. Just check with the specific Vantech you're going with to see how many milliamps you'll need.
    NOTE: Its better to have the fan drawing hot air OUT then blowing air in. In other words, mount the fan so it is "exhausting" hot air, especially if your component draws air in from the bottom. This allows fresh air to flow thru the heat sinks.
  • nebborjk
    nebborjk Posts: 425
    edited April 2004
    I use this fan from Radio Shack it does a great job. I have it wired through the AVR. I agree with Steve, use the fan to exhaust air and remove the heat, not just blow it around.
    Proud SOPA Member since 2005!
  • polkatese
    edited April 2004
    Thanks, Steve!
  • Tour2ma
    Tour2ma Posts: 10,177
    edited April 2004
    I think bullwinkle has a couple...
    More later,
    Tour...
    Vox Copuli
  • polkatese
    edited April 2004
    I bought a couple of these:
    Papst 8412N/2GMLE
    supposed to be one of the quietest fan out there, I'll update how quiet this fan really is.
  • polkatese
    edited April 2004
    Got mine a couple of days ago. Yes, indeed, it is silent, much quieter than the one I have (a taiwanese model) but do need a wallwart with higher amperage to generate enough air flow. I use 12v, 1amp, works great!
