if you break a binding post, is there an easy way to replace it?
pbc74
pbc74 Posts: 63
edited April 2004 in Speakers
...just wondering if this is something that can be easily replaced or if this is a situation where you have to deal with the manufacturer.
Main system:
Fronts: Infinity Alpha 50
Center: Infinity Alpha 37c
Surrounds: Infinity Alpha 20
Receiver: Onkyo TS-XR607
Subwoofer: Pioneer S-DW1-K
Cable- Monster Cable XP
Bedroom Setup:
fronts- Polk R50
surrounds- Polk R30
center- CS1
sub- Sony 50 watt
AVR- Onkyo TSXR502
    F1nut Posts: 52,406
    edited April 2004
    The answer depends. What piece of gear are you talking about?
  • pbc74
    pbc74 Posts: 63
    edited April 2004
    one of my posts on my alpha 20 bookshelfs broke. It was wound up extremely tight when I first hooked them up. I had to use pliers to to unscrew it and I ended snapping it off by accident. It has two sets of posts for bi-wiring so I just used the other set. ...but I was hoping I could easily replace it in case I want to bi-wire in the future.
    Main system:
    Bedroom Setup:
    fronts- Polk R50
    surrounds- Polk R30
    center- CS1
    sub- Sony 50 watt
    AVR- Onkyo TSXR502
    F1nut Posts: 52,406
    edited April 2004
    While I'm not familiar with that speaker, it should be a easy job. If you want the post to be an exact match I would contact the manufacturer. Generally speaking it will involve removing the binding post plate, remove the lead wire (soldered on probably) and unbolt the post. To install, go in reverse order.
  • pbc74
    pbc74 Posts: 63
    edited April 2004
    o.k. thanks.
    Main system:
    Bedroom Setup:
    fronts- Polk R50
    surrounds- Polk R30
    center- CS1
    sub- Sony 50 watt
    AVR- Onkyo TSXR502
