sub in cubbie hole
jravenger
Hi, newbie here one question I just purchased polk 6700 and up
graded to the psw 404 sub. I wanted to know if I place the sub
in a hole in the wall that was used for fire wood, would that cause a problem the hole is approx 20"x20" . It would not be fully closed the opening would not be covered. Also I have read the forum and will be watching mostly movies do I use the sub cable or the speaker wires to hook up the sub.
receiver is Harman kardon 430.
Thanks for any suggestions..
Post edited by jravenger on
Definitely use the subwoofer cable. As for the cubbie hole, I would guess that you'd be losing some impact by putting it in there like that. But you may still like it. Try it out and let us know what you think.Home:
Denon AVR-1803
Polk CSi30
Polk RTi70
Polk RTi28
Polk PSW-303
Car:
Kenwood KDC-BT945U
RF Punch P400-4
Polk MM6501
Polk MM651
RF Punch P300-1
Boston Acoustics G312-4
