Sub Woofer
edwinoc
edwinoc Posts: 1
edited January 2002 in Technical/Setup
    WHEN I TRY COVER MY SUB WO.... FOR PROTECT, BECAUSE THE HUMIDITY IN MY AREA IS TOO MUCH,SUB IN OFF AND THE AMPLIFIER SECTION HEAT UP. I NEED HELP FOR THAT.
    MUCHAS GRACIAS......THANKS, EDWIN FROM P.R
    Post edited by edwinoc on
    • DLK123
      DLK123 Posts: 7
      edited January 2002
      Most subwoofer's instruction manuals indicate that you should NEVER cover the SW with anything. If the situation is that you cover it while it is off. Unplug the unit from the wall outlet. The Amp's transformer is still in operation during 'standby' time. This may be why you have heat while it is off.
      Hope that helps.
      DK
