Telefunken 12AX7's
snow
For sale are a total of 26 Telefunken 12AX7's 13 are smooth plates and 13 are ribbed plates all test above minimum good. The print on some is nearly gone others are in fair condition.
$35.00 each
Regards Snow
$35.00 each
Regards Snow
Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
A quick pic to entice buyers to open their wallets
By chance are any of the smooth plates ECC803S (E83CC)?Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
No I wish
You can spot them pretty fast most have gold pins and all are short plate tubes, all of these are long plate types.
Regards SnowWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
He wouldn't be stupid enough to put a price tag of $35 each if that were the case Bob. I would have bought the entire lot o'them!!!
Not if I had bought them 1st
The smooth plates are all sold.
