Nocturnal Feline Speaker Defence
HA! How you like dem apples.
  • codycatalist
    codycatalist Posts: 2,661
    edited August 2017
    Note only used at night when not listening. Velco straps.
  • codycatalist
    la2vegas wrote: »
    I'd just get rid of that cat with a swift kick in the rump. :o
    If it was mine I would. Daughter adores the cat, can't bring myself to get rid of it. On the plus side it really tames the highs :D
    nooshinjohn Posts: 26,046
    They look like they could also use some "Decor-off" speaker top protection... silly humans anyway,
  • codycatalist
    Touches the Spawn figures she gets it!
    mhardy6647 Posts: 35,342
    edited August 2017
    heh :)
    when I had Altec Valencias, one was grille-less. I cut a piece of hard foam board (like the stuff architects use for their models) to fit over the woofer when not in use. I wasn't about to let a kitteh sink its claws into an Altec 416 woofer :/
    12980008165_d42bcedc8f_b.jpgP1020753 by Mark Hardy, on Flickr
    12289315386_cf252f4e11_b.jpgDSCN5289 by Mark Hardy, on Flickr
    pitdogg2 Posts: 27,490
    Nice idea Cody o:)
    billbillw Posts: 7,937
    1st, clip the cat's nails. Keep them short, just above the pink line. It doesn't hurt them as long as you don't go into the pink/blood line.
    2nd, get the cat a Turbo-scratcher toy and load it up with cat-nip. Show the cat how to use it. They love it! I've had 4 different cats (2 currently) over the last 15 years. They have never even bothered with the speakers. They are totally satisfied scratching the cardboard turbo scratcher.
    https://www.amazon.com/Bergan-Turbo-Scratcher-Cat-Toy/dp/B000IYSAIW
    They sell refills also. Tip: When one side starts to get worn, flip it over.
  • codycatalist
    billbillw wrote: »
    I'll look into it but don't mistake her going for the speakers as a toy or lack of trying other options. Like I mentioned it is usually when the dog riles her up and she runs around then jumps on them to escape.
    I just need to get some speakers to replace the SDAs in the living room and put them away until I get the house with a dedicated room.
    Our very first cat, Griswold (who adopted us when we lived in the Silicon Valley in the late 1980s) had but one vice: He would scratch on the black grille cloth of one of my Monitor 7As! :(
    (I still need to redo those grilles, in fact)
    My short term solution was to replace the 7As in the family room of our old house in MA with -- a pair of dump-find ads L-710s.
    The L-710, which, objectively speaking, is probably a better loudspeaker than the 7A (sorry ;)) also has the advantage of a perforated metal grille! Quite cat-proof.
    Some ads loudspeakers have metal grilles, some fabric... they're (IMO) worth seeking out, irrespective of grille material... but in the context of this thread, the metal grilles could be a value-add!
    Trim the nails did that all the time with ours. In all reality its a must. Many are just trying to wear their nails down to a manageable level. We had several cat scratch toys as bill mentioned. I found he only really used them when his nails were too long and he clicked across the tile floor or snagged on the carpet.
    txcoastal1 Posts: 13,519
    Spray paint the board white and let you daughter to a sticker and art project :)
    EndersShadow Posts: 17,732
    Wheres the electric wire attached to a battery hidden?
    Actually not a bad idear. Thankfully my cat just enjoyes destroying the doorframe casings, so no worry about speakers (I've got my priorities straight :smile: ).
    Alternately, see if the Local Lowes has some leftover fridge boxes, so then you could cover the entire speaker.
    Then like ron said, make it an art project :smile:
  • afterburnt
    afterburnt Posts: 7,892
    I use sticky traps, it's more fun than a barrel full of monkeys
    afterburnt wrote: »
    Till they break something ELSE, normally ONLY something of significant value that's important to your significant other.... then you sell your speaker speakers to replace it.... while your cat grins and grins and grins
  • afterburnt
    afterburnt wrote: »
    Yeah cats are evil like that, funny thing is they try to kill her all of the time.
  • codycatalist
    txcoastal1 wrote: »
    Not a bad idea at all. I might just do this!
    You could paint it black, but black paint is oh so hard to source.
    I place the blame on the Glimmer Twins.
    https://youtu.be/O4irXQhgMqg
    I'd spray it with that anti cat juice. Cat won't get close to them anymore.
    Problem solved.
    By the way Cody how you come up with that idea? B)
  • codycatalist
    Problem solved.
    Actually I did spray them down with anti scratch spray just in case. :)
    Funny thing, you know those moments when your other half explains an idea the complete wrong way then you think of it months later and claim authorship? Well that's what happened.
    Hmmm. She had a great idea then didn't she
  • Best solution that I have seen for cat claws. Great for homes with little kids running around and cats that like to stretch their toe muscles (that is actually what they are doing, not claw sharpening). Our vets in our small towns have hundreds of local cats wearing these crazy things and everyone is talking about how much they love it for their cat instead of the dreaded declaw procedure.javgdj71qlek.jpg
    https://www.amazon.com/dp/B01NC2P9BP/ref=asc_df_B01NC2P9BP5124306/?tag=hyprod-20&creative=395033&creativeASIN=B01NC2P9BP&linkCode=df0&hvadid=167144469268&hvpos=1o1&hvnetw=g&hvrand=9773752384646004062&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9026448&hvtargid=pla-335324202444
  • FestYboy
    FestYboy Posts: 3,861
    Never declaw a cat!!! No only is it mutilation, it also (usually) negatively changes their personalities (takes the "cat" out of the cat). I've seen this on several occasions. Claw caps are a novel solution, but in the end, a PITA for both parties. A weekly trimming is all that's needed.
  • codycatalist
    Yeah declawing is not something I considered. Once we get a house if there is a doggy door I'd prefer her to be able to defend herself.
  • codycatalist
    Gotta love her. In all seriousness I was just at work tired from the cat meowing locked up in the bathroom all night and was thinking "Maybe I can find boxes big enough to fit over the speakers at night". After internally deliberating for a couple moments I though why not a project board and they can fit around via Velco and hot glued straps.
    Voila Nocturnal feline speaker defense was born.
    Might just patent it. Unless one of you Edison's does first.
  • codycatalist
    We tried the claw covers. Our cat would just bite at her claws till she ripped them off and we'd find them all over the house. And not realize one was missing until she scratched something else up so we saw it wasnt there :frowning:
    msg Posts: 10,515
    Man, Cody, those things look factory! I wouldn't even have noticed if you hadn't pointed them out.
  • codycatalist
    msg wrote: »
    Maybe I should forward this to @KenCustomerService as a feature for the New SDAs Ha!
