Any interest in Belden 1506A ICs?
codycatalist
Came upon a good amount (will have to measure but at least 50+ feet) of Belden 1506A that are already terminated with RCAs. They are used and will post pictures in a day or so once I have time. Just seeing if there is any interest or if the wire is "good".
Thanks!
Thanks!
http://m.markertek.com/product/bl-1506a-1000/belden-1506a-rg59-20-sdi-plenum-coaxial-1000ft-black
Info to help
I have used belden but has always been the rg6.
rg6 is 18ga. this is rg59 which is 20ga.
Both solid copper instead of copper clad steel -
Info to help
It seems obviously they are mostly used for in wall, would you consider it a decent cable for shorter runs like 3 or 6 feet?Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
CATV cable.
rednedtugent wrote: »CATV cable.
This day in age most of that is RG6 as well due to the wire gage.
I don't know Cody just try and see is all you can do. Google it up and see.
