rti100 connections
bvette94
bvette94 Posts: 356
edited April 2004 in Speakers
Hi all ,I need advice on the best way to hook up a pair of rti100 front powered sub woofers and the polk powered sub woofer model number 650 my question is is it best to use the lfe imputs and loop the in and outs for the powered sub woofers or use the lfe for the just the powered sub 650 and keep the gold bars in place.this info is for a buddie his reciever is a sony es model also what is the rev normal funtion on the powered sub ,what should it be set to. any help would be great .
thanks
denon avr 5800
denon dvd 2900
rt800 fronts
cs400 center
fxi5 rears
infinity bu120 sub
mitsubishi 55 hdtv
monster power center 2500mk2
  • Airplay355
    Airplay355 Posts: 4,298
    edited April 2004
    the gold bars dont have anything to do with the sub, they connect the woofer and the tweeter. ur in kind of a tricky situation because the sub in the rti100's isnt all that powerful so you dont really want to devote alot of the bass signal to them but at the same time you dont want them to be wasted.
    i guess the best way to encorporate them into your HT would to use the lfe signal with the rti100's and on the 650. but then again that might not be the best way because as you turn up the volume, the rti100's will distort faster then the subwoofer will. hmm maybe thats not such a good idea lol.
    another alternative would be to hook the rti100's up like regular speakers and use the lfe to the sub only, then, assuming you have bass control on the receiver, lower the crossover frequency to 60 or 40 hz. you are really going to have to try it and decide how it sounds.
    sorry for the confusion but i was figuring this all out as i typed. im sure some more clear headed members will fix the mess i made.
  • dorokusai
    dorokusai Posts: 25,661
    edited April 2004
    I vote for Airplay's alternative....sounded good to me man :)
    RTi100's "Large" and use the LFE for the subwoofer. Use 80hz for the filter/crossover....or lower, it's up to you and your listening habits. That should sound great, but it's just a suggestion.
