6.5" in GM's
DizziD
I just bought an EX3065 component set for my 93 Saturn. The problem is GM must not like people messin with their cars n' they got those oversized speaker openings. since the mounting holes on the speaker don't reach all four holes on the door, i am forced to use only two screws to hold the speaker in place. Is there someplace where i can get an adapter to mount these speakers properly?
Post edited by DizziD on
check your local stereo stores, and crutchfield. Both will usually have some thing.Speakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
you can also make your own custom mounts.... and yes..GM is funny that way with thier mounts..my wifes van had mostly clips and wierd brackets to hold them in...
