RT 55i:Large or Small?
chiuahua
:cool:
HI!
What is better in set-up?
Receiver:Yamaha rx-v 800.
Front: Rt 55i : Large or small?
center: Cs 245i small
rears: Rt 35i small
Sub: Velodyne cht-10
Thanks!
HI!
rears: Rt 35i small
Thanks!
Post edited by chiuahua on
I'm guessing people are going to suggest setting the 55i's to large, while keeping all other speakers to small. Having said that, try listening to both settings and see if you can hear a difference and decided which is preferable.
I have the 800i's set to large and think it provides a more full front soundstage, and your 55i's are essentially the same speaker. -
Ok!I will try.
Thanks.
