Room Layout
monkeyphant
What are the little circle things?
I'm guessing lamps Polkmaniac. My question is, does he have rear surrounds on the bookshelves or is this a 2-channel rig with subwoofer.Money Talks, Mine says Goodbye Rob!!!!
The TV looks like a 13"er and the speaker toe in appears to be on the radical side.
What's behind the TV ? a large window ? -
OOOOOrrrrrrrrr, It could be a screen for a projector. Wait a minute, where is the projector?:D All joking aside, what are the dimensions of that room. I see a PB2 in the corner, would really like to know the size of that room. I have a 3000 +/- cu.ft. room and sometimes I feel the PB2+ is to much. Forget that last comment.:DMoney Talks, Mine says Goodbye Rob!!!!
Right ...
It's hard to visualize how things will fit without having stuff to move around etc. but my first thought was to use what is the top wall in the picture as the sound stage. Access to the room right now seems to be a little difficult and having a solid back wall ( bottom ) might improve PB2's output. -
Go back to the original post for a descrption of the "little circle things". The boxes are tower speakers that are toed in. The rectangle on the front wall is a projector screen. The rear speakers are mounted on the rear wall...you guys are rough..
Sorry ... not trying to be rough ... just trying to get an idea of what's going on. Where's the original post ?
Originally posted by monkeyphant
Go back to the original post for a descrption of the "little circle things". The boxes are tower speakers that are toed in. The rectangle on the front wall is a projector screen. The rear speakers are mounted on the rear wall...you guys are rough.. -
We monkeyphants have a hard time expressing ourselves..the long snout gets in the way sometimes.
They're in the bass management thread ...
Ah man, I have really hosed this up...if you could go back to the Subwoofer forum, that should work...sorry...
the only problem i see with your drawing is there isn't any beer in the picture.
all subs sound better with plenty of beer on hand.PolkFest 2012, who's going>?
