Best speaker stand for rt55i <$150.
Guys-
Wondering if any of the Sanus speaker stands on the polk store link are fillable (sand or lead)?
Do they do the job?
-Luc
Do they do the job?
-Luc
The Sanus stands recommended on the club shopping page seem to be 18" high. I'd recommend 24" stands to get the tweeters a little higher so they're at ear level. A problem with many speaker stands is the base plates get to be too small for larger bookshelf speakers the taller the stands get. The most stable stands I've found are from PartsExpress, and these can be filled:
High Mass Monitor Speaker Stands
I've had a pair of them for a few years. Their dimensions and stability are perfect for RT55is. -
I have my RT55is on the Sanus NF 18" stand and the tweeters are at a PERFECT height for my listening position. The are not fillable but they are very stable and look good too (IMO). I have not used the Parts Express Stands but I have heard good things about them. I would go with no more than 18" however. The height of the stand and the height of the speaker put the center of the tweeter at around 36" to 37" from the floor. Here is a picture of mine:"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
And another:"Just because youre offended doesnt mean youre right." - Ricky Gervais
Looking good Shack.
Dayton sub looks bitchin', and so does you wiring at the wall plate.
Cheers,
Build a pair for less than 50 bucks!
I built my stands based on this design. My stands cost about 90 bucks because I used hard wood. if you used MDF the cost would be considerably less. They are rock solid when filled with sand, they probably weight around 50 or 60 pounds. With my speakers on they they weigh 75 to 85 pounds.
Your other option could be these stands from Parts Express. They are supposed to be rock solid and a great value. Those were my first choice before my DIY stands but the top plate was wider than my speakers.
More pics of my stands
Construction PicsSony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Double post...Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
Emlyn- excellant link, a very strong contender, they are heavy on their own,
and filled with sand?
I could get rid of the barbells.
Shack- very clean looking units, and definitely a bargain.
Tryrrthg- argh argh argh! Or should I call you Tim "the toolman" Taylor.
Excellant link. I liked your design even better.
You know, I've thought about doing this for some time. It is cool to make your own stuff.
Are your speakers attached to the stands? Or do they just sit on top?
-Luc -
Great looking stands and informative construction pix ... Good job.Originally posted by tryrrthg
Build a pair for less than 50 bucks! -
My names Troy but you can call me TimOriginally posted by trubluluc
-Luc
Thanks for the compliments. My speakers just sit on the stands but they are attached using some re-usable adhisive puddy. It's that stuff you use to hang posters on your wall. It works great, my stands would fall over before my speakers would come off the base. Although my stands would have to be hit pretty hard to fall over.
The project was pretty easy and it's always great to make something yourself. The staining and sanding was a pain but it was worth it in the end, and they saved me about $200 off of the stands I wanted. It's also nice to make them youself so you can make them look exactly how you want them to.Great looking stands and informative construction pix ... Good job.
Thanks!Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Check out this website for stands...
http://www.racksandstands.com/asp/show_cat.asp?catid=6
You can get pretty nices ones for around $100 delivered....all different heights and most are loadable.
I'm going to be getting a pair for my Studio 40's but I'm just trying to decide what height I want.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
trubluluc,
I have my 55's on these (filled with sand). For the money, these are first rate and they have excellent CS. I paid less for mine, e-mail them and see what they can do. I'll post a pic tonight.
http://www.vidsonix.com/vidsonixnew/vidsonix_accessories.htm
Good luck- GregAVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One -
gacole2000,
Nice price....any idea what they weigh w/out filling?
Thanks.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
I got mine off e-bay, for a great price. I looked all over, and these were by far the best value I found. I have been very happy with these stands.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14989&item=3089685192
I'm not sure how much they weight, but they are heavy duty metal, much better than the wood Sanus stands I looked at. E-mail them and they will get right back to you. They also have excellent CS!AVR: Yamaha RX-V661
BR: Samsung 1600
Center: CS300
Sides: FX1000
Rears: RT/FX
Another pic, sorry so large dial-up members.
Nice job on the DIY stands tryrrthg!
AVR: Yamaha RX-V661
BR: Samsung 1600
Center: CS300
Sides: FX1000
Rears: RT/FX
Well, I just ordered a pair for my Studio 40's. I thought the website that I'd found was a great deal but this price is hard to beat....thanks, appreciate the link.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Both websites look like they have some nice stands....and the free shipping would have been great, but I already ordered the set from "Parts Express" $99. bones was a deal, but the $48. shipping kinda sucked.
anyway...
-Luc -
nice set up there man!
is that an SVS tube peeking out in the corner of the picture.
My SVS box was supposed to be here today, hopefully tomorrow.
late,
-Luc -
Thanks Henry, that is very kind of you! A work in progress :-).
I am waiting to get my HDTV Dish 811 (Tuesday) and then I'm going to take some better pictures and post them in the showcase.AVR: Yamaha RX-V661
BR: Samsung 1600
Center: CS300
Sides: FX1000
Rears: RT/FX
SVS pic. This thing is huge-awesome!AVR: Yamaha RX-V661
BR: Samsung 1600
Center: CS300
Sides: FX1000
Rears: RT/FX
What High Def service are you going through. I have had D* for 4 years and am a very satisfied customer. HDef will blow your socks off!
HBomb***WAREMTAE*** -
Dish Network. It has taken 4 months to get my 811 in, so I'm dying here! I want to ISF calibrate my TV next, and with a baby on the way, I'll have to slow down for a while.
Do your ever go to the Chief games? Maybe we could get together one Sunday after a game to jam a little, I usually have extra tickets .
Take care- GregAVR: Yamaha RX-V661
BR: Samsung 1600
Center: CS300
Sides: FX1000
Rears: RT/FX
Take care- Greg
WOW congrats on the baby... is that your first?
Oh YA on KC Football even though I'm a Pittsbugh boy KC Stadium puts out some serious dB's.:D and I have always been a Chiefs fan. Absolutely lets plan on that.
I have been meaning to do the ISF cal but just keep putting it off. Polkthug(Toby) was over last weekend and he's a vidio head and made some adjustments for me. I have to say it does look better but I just don't have an interest in really refining vidio the way it should be. Audio is enough.
On a slim chance have you ever ran into a dude named Jeff Tomlin? He is one of the finest people I have met and lives in Springfield.
Yes, our first child. I go between thrilled and freaked out ;-)
We will indeed plan a post-game get together!
His name does not sound familiar?
Have a good one, I'm calling it a night.
Have a great Easter!
BR: Samsung 1600
Center: CS300
Sides: FX1000
Rears: RT/FX
I have a pair of these I'm trying to rid of. 10/10 condition. I'll give you a smokin' deal if you're interested.Home Speakers polkaudio RTi70's (bi-wired), CSi30, FX3000i, PSW250
Car speakers polkaudio EX 369, DB 650 -
not sure if I can attach the pic. They're the stands I have in my showcase if you want to look at them.Home Speakers polkaudio RTi70's (bi-wired), CSi30, FX3000i, PSW250
