RTi12 Speaker Break in?
trend1
trend1 Posts: 36
edited April 2004 in Speakers
Hi All! Newbee question here! I just purchased the RTi12 and after reading many post here I read about speaker break, how do you properly break them in and what happens when they do break in?
Thanks, Tony
Mains: Polk RTi 12 (Bi-Wired)
Center: Polk CSi 5
Surrounds: Polk FXi 3
Rear: Polk FXi 3
Sub: Polk PSW505
Receiver: Denon 3805
Power Amp: 2 Outlaw M-Blocks
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited April 2004
    I broke mine in by playing them for quite awhile at low to mid volumes. When I first got mine I was surprised how shrill the highs seemed as they did not sound that way when I auditioned them with the same equipment. Although there are varying opinions about whether or not speakers need to be broken it at all and if so for how long, I'd say mine took something like 20-40 hours of low to mid range volume before the edge on the highs disappeared.
  • trend1
    trend1 Posts: 36
    edited April 2004
    PolkWannabie, It's funny I to was suprised how shrill the highs seemed when I got them home out of the box as well! Thanks for your advise.
    Tony
    Center: Polk CSi 5
    Rear: Polk FXi 3
    Sub: Polk PSW505
