Bass Tubes
Systems
I was wondering about these bass tubes, are these things any good, like the ones from bazooka, they have really good sensitivity.
Testing
Testing
Testing
Testing
Testing
for a budget sub, not bad. other than that, nope. i'm pretty sure kenwood's got something called the w00x system that is a drop-in sub, like bazooka. ive never heard it or anything about it tho. probably better sq than bazooka tho.
read this threadIt's not good, very fundamentally simply not good. - geolemon
how do you know how big to build a box?Testing
Testing
Testing -
the specs for the sub will tell you. sometimes it'll give you a range, with smaller being tighter and bigger being lower and maybe a bit quieter. sometimes, a company is nice enough to give you a box plan. or you can ask me, and ill design one because i like doing that kind of thing.It's not good, very fundamentally simply not good. - geolemon
