FS: 4 x Duelund CAST 10 Watt 22 Ohm Resistors
VR3
So I have 4 of these... 22 ohm, pretty common value
Normally around $48ish per resistor...
Will let all go for $100 shipped with paypal or a pair for $58 shipped with paypal
Pm inbound
responded- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
If these are 1.2 TL and not sold yet, I will take them allThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
The 1.2TL uses 2 x 22.5 ohm resistors, a pair of these would work fine... I do prefer to simply sell them in a set...
Will see what MSG says- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Msg passed you would them @nooshinjohn- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Pm sent...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Two down, two to go...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
2 spoken for, 2 available- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Bump, PMd Nooshin to see if he still wants them, two available at this time- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Bump, still have a pair- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
