What is difference between Adcom GFA-545 and II?
sdurfee
sdurfee Posts: 8
edited April 2004 in Electronics
Hi. I bought a used Adcom GFA-545 to drive a pair of Polk LSi-15's. In the manual, it only mentiones a reference to 100w x 2ch at 8ohms. The GFA-545II mentions 150w x 2 ch at 4ohms. The Lsi-15's apparently need 4-ohm power. I'm assuming that the GFA-545 will do me okay but could you verify?
Also, this is the first time I've hooked up an amp. I have a Pioneer Elite 35tx
receiver (90w x 5ch) that has RCA outputs for additional amps? Once I hook up the Adcom to my main 2 channels and the speakers to the Adcom, how doe the Pioneer interact with the amp? Does it completely bypass it's own 8-ohm power for those channels and just let the Adcom take over? I'm assuming I'll still be able to do 5 channel audio just that my surrounds and center will handled by the Pioneer while the Lsi-15s by the
Adcom?
Extremely novice at audiophile stuff so forgive the ignorance ....
- Steve
Post edited by sdurfee on
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited April 2004
    I haven't looked at the details but here are the manuals ...
    http://www.adcom.com/pdfs/gfa545manual.pdf
    http://www.adcom.com/pdfs/gfa545iimanual.pdf
    It appears the manufacturer describes the differences early on in the 545 II manual.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2004
    >>Does it completely bypass it's own 8-ohm power for those channels and just let the Adcom take over?<<
    Short answer is YES.
    Another way to look at it would be, the power not needed on the fronts channels may help the other channels make power. ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    VR3 Posts: 29,556
    edited April 2004
    Adcom, IMO, downgraded the 545 II over the 545 original.
    The original uses blue caps! ;):D, bigger terminals (accepts up to 12 awg wire), everything about it seems to be better. The 545 II, I have had alot of problems with it distorting, etc.
    The original line, 535, 545, etc seem to be better to me.
    Just my opinion, the original line also has a 'sweeter' sound to me.
    The 545 and the 545 II can and will drive the LSi line without any problems. Over-heating? hehe, Adcom runs hot anyways. You can cook an egg on Adcom amps, so make sure they are well ventilated!
  • sdurfee
    sdurfee Posts: 8
    edited April 2004
    Thanks for the reply. I have descent thick set of Monster speaker cables that have built-in banana plugs for both input and ouput. Does the GFA-545 have multiple types of connections? Just wondering if I should sell the Monsters on eBay and get ones with bananas on one end (for the Lsi's) and something else on the other.
    I mean I could hack one end up myself but there's something to be said about something engineered by a professional.
    - Steve
    VR3 Posts: 29,556
    edited April 2004
    yes, the 545 II accepts nanners, and I believe the 545 does too. Pretty sure.
