CS400 versus CS400i ?
trubluluc
trubluluc Posts: 2,067
edited April 2004 in Speakers
Guys help me out here.
What is the difference between these two speakers, other that the color of the driver material?
I've looked at PolkAudio and can't even find a cs400 listed.
thanks,
-Luc
  • HBombToo
    HBombToo Posts: 5,256
    edited April 2004
    I have never called Polk requesting a rebuild of my 400i but I'll give you my best guess. I'll assume the 400 to 400i conversion is very similar to when I converted my 55's to 55i's... different tweeters and crossovers. There was no advice from Ken regarding the woofers.
    HBomb
    ***WAREMTAE***
  • trubluluc
    edited April 2004
    I did a little digging in the archives and came up with this from "the Doc" and "the Rooster".
    'Black woofs vs. blue woofs. And the tri-lam was a hair different - designed to be smoother. Virtually indistinguishable for most purposes.'
    __________________
    'Apparently quite a few felt the original RT trilam was a little bright, and the 'i' series was designed to retain the same tonal character, but remove that 'edge' in the upper most octaves.
    As far as I'm concerned, I've heard several RT and the first gen RTi side by side, and can't tell a lick of difference. For all intents and purposes, they are the same speaker (to me).
    Cheers,
    Russ'
  • HBombToo
    edited April 2004
    Cheers,
    Russ'
    My opinion also! and no problem.
    HBomb
    ***WAREMTAE***
  • Marty123
    Marty123 Posts: 32
    edited April 2004
    What about the CS245 and CS245I does the same hold true?
  • HBombToo
    edited April 2004
    I would imagine so.
    HBomb
    ***WAREMTAE***
  • kelley
    kelley Posts: 287
    edited April 2004
    I have one of each and cannot hear a difference.
    SDS-400, SDA-1B, SVS 20-39pc+, B&K Ref 50, Denon 2900
