priority
parke 15
parke 15 Posts: 7
edited January 2002 in Technical/Setup
can anyone answer a question that has me puzzled?
When setting up a dvd player/cd w/sacd with decoder built in and then setting up my av receiver--- which setup has priority ?
Post edited by parke 15 on
  • hoosier21
    hoosier21 Posts: 4,420
    edited January 2002
    me thinks they are equal priority, they both think they have to work, you should only use one decoder, I would pick the reveivers decoder unless the DVD players is more flexible or advanced.
    I do not have a DVD with built in decoders so I might by talking out my a$$ here, but if you use both you will have a mucking fess.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
