Carver M-4.0t is this common ground and will it work with my SDA2Bs
I want to use this amp with my one pair of SDA2Bs 2 channel stereo set up! Does anyone have any exp with this particular amp? Does it sound good?
Answers
  • honestaquarian
    honestaquarian Posts: 3,259
    This is the very first iteration of what later became the TFM-45 and then TFM-55 and TFM-55x amps. I own a TFM-45 and yes they are common ground. This is the amp that was supposed to mimic the sound of Carver's Silver Seven tube amp. You will find the name Carver tends to ignite strong opinions on both sides on this forum. I've been a Carver fan for decades.
  • If your TFM-45 is the same as the M-4.0t then How Does It Sound? I have a line on one right now along with the CT-7 preamp should I go for it or get a different amp all together?
  • honestaquarian
    I ALWAYS loved the sound of Carver and Polk. Just very synergistic to my ears. Which is why I have been combining the two for thirty years.
    If you have never heard this amp then what you think of it may be the total opposite of my opinion.
    Or not
    I suggest seeing if you can have a test drive with your speakers to see if you like it or not.
  • daddyjt
    daddyjt Posts: 3,172
    ... You will find the name Carver tends to ignite strong opinions on both sides on this forum...
    This is very true - Carver amps are solid mid-fi fare, in the same category as Parasound, Rotel, NAD, etc... I am also a Carver fan - their balance of fidelity, output, size, and price are tough to beat. The 4.0t/TFM 42/45 family are quite stout - the TFM 45 especially is a particularly sought after model, even more so than the more powerful TFM 55.
    My advice? Listen to as many different amps as possible - there's no substitute for actually hearing them...
    ― Aleksandr Solzhenitsyn
  • I am tempted to pull the trigger on the M-4.0t and CT-7 but I want a natural/neutral sound with good bass! What about Parasound,Soundcraftsman,Emotiva type amps? I could end up spending several thousand to go through the carvers and not like the sound of them in the end!
  • daddyjt
    Can you buy just the 4.0t? And how much is it? They go for $500ish on eBay, so if you get it for a good deal, you can always flip it. The CT-7 isn't really worth your time, IMHO...
  • honestaquarian
    Again see if the seller will allow you to audition the amp with your speakers before you buy.
    F1nut Posts: 52,103
    It sounds nothing like the Silver 7 tube amps, nor the Silver 6 or 9. In fact, none of Carver's SS amps sound anything like a tube amp.
  • honestaquarian
    F1nut Posts: 52,103
    I am a Carver fan, of his tube amps as they are stellar. I don't care to ever hear another of his SS amps except for the Lightstar, but that's not really a Carver amp.
  • honestaquarian
    edited March 2017
    Why do you say it's not really a Carver?
    He designed it himself using his tracking downconverter patent that he FINALLY figured out how to make work right before he got booted out of Carver corp by the very same people that HE brought in. The Lightstar (*the first version*) is the predecessor to the Sunfire amps that he later created.
  • If I am going to spend between 500-1000 I want to by an amp for my Polk SDA2Bs and not have to look back whether it be Carver or other Common Ground Amps! What are some good others besides Carver that would leave no dought...?
  • honestaquarian
    Parasound
    Rotel
    Proton
    Onkyo
    Denon
    NAD
    Adcom
    Marantz
    To name a few
    F1nut Posts: 52,103
    Nope, your history is incorrect. Jim Croft is responsible for the Lightstar.
    F1nut Posts: 52,103
    No one can honestly answer that. I'd suggest you hit up a few audio dealers and friends. Get your ears on as many rigs as you can as it will give you a much better idea of what may sound good to you.
    heiney9 Posts: 25,552
    Very true. Too much hype and not enough substance surrounding that issue back in the day.
  • george daniel
    george daniel Posts: 12,096
    Belles
  • honestaquarian
    edited March 2017
    Sorry F1 but your history is incorrect.
    Jim Croft is responsible for the SECOND version of the Lightstar (*the one with the single meter*) Which was a few years AFTER Bob Carver was gone and had started up Sunfire. The Lightstar has the same Tracking Downconverter, continuously variable, signal tracking power supply (*which predates pretty much all class D amps*) that the Sunfire amps later had. Bob Carver had patented that power supply over a decade prior, but couldn't get it to work. That is what brought him to create a sort of halfway version of a signal tracking power supply that he named the Magnetic Field power supply. Which moves up and down in three discreet steps instead of a continuous variation like the Tracking Downconverter. He started up Carver Corp with the Magnetic Field Power Supply in the M-400 cube amp (*of which I've owned four in three different generations and still have and use one*) He revisited that patent and discovered how he could finally get it to work and designed the Lightstar (*and he was the one who named it*) Submitted the design to his engineers and went on a sabbatical. When he returned,he and his Carver Execs had a major disagreement about what direction the company should be going in and they voted him out.
    This information came from Bob Carver himself and is available if you look up any of the interviews he has done over the years.
    Oh and btw to @Cylontymany the OP (*Original Poster*) The M-4.0t has a Magnetic Field Power Supply.
    F1nut and I do not always agree (*the same can be said of pretty much everyone here with each other*) Sometimes I am wrong and he is right and vice-versa. However he has earned my respect, because he knows wtf he is talking about.
  • Ended up with a Sunfire 300x2
    nooshinjohn Posts: 26,042
    Good choice...
