Nice Yamaha MX 2 150w/ch high current power amp
geppy1
Selling
my Yamaha MX2 power amp that is in excellent condition and works perfectly. The faceplate is real nice as is the top but there are a couple of light scratches on the top. The MX 2 was made 1992 to 1997 and was one of Yamaha's better efforts. It puts out 150 watts per channel into 8 ohms and 230 into 2 ohms. It can drive low impedance loads and has high dynamic output into 2 ohms. Specs below. The amp can drive 2 sets of speakers and has level controls on back. It is built like a tank and weighs over 40lbs. It also is very attractive and has a sleek look to it. I can ship at your cost and my packing is excellent. Asking just $350 Thanks
MX-2 Specification
Minimum RMS Output Power per Channel:
150 W (8 Ω) from 20 to 20,000 Hz at no more than 0,008% THD
190 W (4 Ω) from 20 to 20,000 Hz at no more than 0,03% THD
230 W (2 Ω) from 20 to 20,000 Hz at no more than 0,09% THD
Dynamic Power per Channel (by IHF Dynamic headroom Measuring Method):
190 W at 8 ohms
310 W at 6 ohms
410 W at 2 ohms
Dynamic Headroom :
1,03 dB at 8 ohms
2,12 dB at 6 ohms
2,51 dB at 2 ohms
Power Bandwidth (8Ω, 0,03% THD, half Rated Power): 10 to 60,000 Hz
Damping Factor
(SPA, 8Ω, 20 - 20,000 Hz) : 350
(8Ω, 1 kHz) : 250
Input Sensitivity/Impedance (Main IN): 1,26 V/20 kΩ
Frequency Response (Main In): 20 to 20,000 Hz, ±0,5 dB
Signal-to-Noise Ratio (IHF-A-Network): 123 dB (Main In, Shorted)
Residual Noise (IHF-A-Network): 20 μV
Channel Separation (Vol -30 dB, Main In, Input 5,1 kΩ terminaled)
1 kHz/10 kHz : 80 dB/ 60 dB
Dimensions (W x H x D): 438 x 116 x 486 mm (17-1/4 x 4-9/16 x 19-1/8 inch)
Weight: 19,5kg (43 lbs)
MX-2 Specification
190 W at 8 ohms
310 W at 6 ohms
410 W at 2 ohms
Dynamic Headroom :
1,03 dB at 8 ohms
2,12 dB at 6 ohms
2,51 dB at 2 ohms
Damping Factor
(8Ω, 1 kHz) : 250
Rear
SOLD
