mm10 and c300.2
Systems
I am fairly new to car audio and i just purchased a mm10 and a c300.2 and i was wondering if this setup is alright when the amp is bridged to 550w. leave inputs please. thanks
Testing
Testing
Testing
Testing
Testing
i have heard reports of the cone hitting the grill at high excursion, so if that happens, you can dremel it out a bit, but other than that you should be dandy. just set the gains properly (if u dont know how, just ask). cody (exalted###)may be able to offer a better solution to the grille problem.It's not good, very fundamentally simply not good. - geolemon
thatll be perfect...
polk needs to go back to the drawing boards on the grilles
*shakes his head*
-CodyMusic is like candy, you have to get rid of the rappers to enjoy it
