Polk PSW450 with 60hz AC power
Is that an issue? I would of course have a step down transformer for the 220V.
Best Answer
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Answer ✓
    You asked about 60Hz in your title, so I assumed this is what you have. But, in either 50 or 60 Hz the sub will work fine. The internal amplifier operates from DC voltages, so once the power supply converts AC to DC the rest works accordingly. Under some power supply designs there could be slightly higher noise with 50Hz, but I don't believe this will be a problem with the PSW450.
    Cheers, Ken
Answers
