polk dx12
Systems
Systems Posts: 14,873
edited April 2004 in Car Subwoofer Talk
what do you guys think about this sub? i can get a single dx12, brand new, for $60. which i think would work fine with my amp, it does 560x1 at 4 ohms...?
Testing
Testing
Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited April 2004
    hell yes it'll sound great -- u're not gonna use all that power... u'll only dump maybe 400-ish on it at most, but it'll be fine, be loud, and kick the **** outa most other subs on the market today.
    i've owned like 10 or so dx subs in my time... it's crazy ****.
    The Artist formerly known as PoweredByDodge
  • Systems
    edited April 2004
    well it should sound better then my 2 gnx104's
    Testing
    Testing
    Testing
  • exalted512
    exalted512 Posts: 10,735
    edited April 2004
    anything would sound better than the gnxs....or was it the gxrs...egh...i forget
    -Cody
  • Systems
    edited April 2004
    well my gnx's sound pretty good, but i want something new. the amp i have is a power acoustik LT980/2. It does 220x2 @4ohms, 280x2#2 ohms, 560x1 bridged at 4 ohms, and 980 max bridged....
    Testing
    Testing
    Testing
  • PoweredByDodge
    edited April 2004
    that'll be fine on the dx sub -- i freakin hated the gnx and gxr subs -- a disgrace to polk -- polk isbetter than that -- and they have made good on it with the revamping of the momo sub line -- the beefy 10 and 12" momo's stay and in comes some more lighter power 8 10 12 and 15" subs that bring back the "polk-ness" of the old db and dx subs... tickles my heart.
    if i can sell the idmaxes / 81000d's then i'm gonna get an 800 - 900 watt good quality class AB and run two of the MM2104's off it. slammy slammy, punchy punchy....and wont take up too much space either... which'll make me happy.
  • Systems
    edited April 2004
    well i got the DX12, $68.50 with tax, now i just need to build a box for it, and find where exactly i wanna put it. it is going in a 92 camry. i was thinking i could build a box to sit kinda "flush" with the side i guess you could say, like behind the wheel well, but when i measure everything out, and its too much touble, ill go with a more simple box, what would be a nice way to cover the box, and where could i get a decent grill for the sub?
    Testing
    Testing
    Testing
  • exalted512
    edited April 2004
    get the same color carpet as your trunk to cover it
    -Cody
  • Systems
    edited April 2004
    i just need a grill for the damn thing now...and ill pass on the plain black ones...
    Testing
    Testing
    Testing
  • PoweredByDodge
    edited April 2004
    the kicker comp VR grille with the "teeth" is nice lookin and should fit just about any 12" sub.
    if the momo grille will fit, that'll be cool too.
  • Systems
    edited April 2004
    how long should i break it in for? and is there a way to go about breaking it in that is maybe better or easier...
    Testing
    Testing
    Testing
  • PoweredByDodge
    edited April 2004
    play it at 1/4 to 1/2 volume for 2 weeks.
    then slam the **** out of it.
    the dx subs really DO need a break in period.
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited April 2004
    yes, you will get great sound out of your dx. I have 2 DB12's which are older versions of the DX. I was running 700w total for them... shakes the living crap out of you. Then my friggin amp blew up (Kicker DX700) NOW i run my emergency 4 channel kenwood bridged to 2x150w. It still gets a LOT of response.
    Oh... if anyone has an old 700-1000w amp lying around... My 6x9's want that little kenwood back (Bass comes first :D )
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
