All entry level subs the same??
danielhall3
Many of you have or have had the psw202. I am reading a lot about the woes of this sub; poor sound, amp blows, not Polk's forte` etc. The question that keeps coming to my mind though is are there any other sub out there for 100 clams that is better.
Is there that much diffrence between the entry level ($100 -$200) subs out there; Polk, Sony, Yamaha, other?
Also, how important is the power of the amp? Would the psw202 with a 200w amp be twice as good, all else being the same?
I am looking at the psw202 or other entry level sub because a. speakers are not a priority right now on my limited cash flow, and b. a little sub is better than no sub.
Try this....
http://www.consumerdirectonline.com/r-s108ps.htm
I used to own two of them. Check the reviews for this sub on www.audioreview.com.
Don't worry too much about the power rating on amps. Highly overrated. What really matters is how it sounds.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
IMO most of the entry level subs are the same. They are tuned in 35-40 Hz area, small box, cheap driver, modest power.
The Dayton kit subs from www.PartsExpress.com seem to be very popular.
The 202 with 200W would probably be better but it is not worth the effort.Graham -
I had the 202 with no problems... they carry a 5 year warranty. its covered anyway.. I liked it and it never distorted for me, calibrate it and your golden.
It works well with music.. and movies with a reasonable volume..
If you want a sub on the cheap.. the polks and velodynes work fine,MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
I had the Sony SA-WM40 and was very happy with how well it did for the cost. It was a very popular sub and I think the new generation of Sony subs is popular as well.Front
Polk RT800i (BI-wired)
Rear
Polk RT600i
Center
Polk CS400i (BI-wired)
Sub
SVS 25-31PCi (22Hz tuning port)... it's SubHuman
Receiver
YAMAHA RX-V1400
TV
Mitsubishi WT-46807 HDTV
HD receiver
T i V o HR10-250 -
Thanks all, this is very helpful!
i had the sony wm 500 same as the sony mentioned above. its inexpensive (less than 150.00 on the internet and ebay) and can be modified (do a search, the mods are easy to find). the sony with the mods yielded a very solid performer. i was very surprised how well i tperformed musically as well as for movies in its price range.
another choice, while i have never heard it myself, but i have heard good things. from parts express, as mentioned above. the link to the item is below. for 109.00, i hear thing thing is pretty solid.
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=300-632Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
IF you can afford a little more I've heard that the entry level Hsu sub (STF-1) is much better than the other low cost subs. Hsu sells it direct at http://www.hsustore.com/stf1.html. You might be able to get it cheaper somewhere else (ebay?)Mains: Polk RT800i
Center: Polk CS400i
Surrounds: Polk RT35i
Sub: SVS PB1-ISD
Receiver: Harman/Kardon AVR 520
