Room design ………….. Crazy or genius?
If all goes well, I should be closing on the new house in about three weeks. That will give me a walkout basement that is 8" X 27’ X 44’. See the pictures that show stair placement etc. This is my space and I have decided to use it for a game room, half bath and a dedicated listening room. Listening room gets first consideration and I am looking to use 8H, 13W and 21L dimensions. These dimensions may change as needed. I am considering using tapered walls from back to front moving in 18” near the speaker wall on each side. Also want to taper the ceiling 18” from back to front. The end of the tapered walls and ceiling will be open at the speaker end. The thought process is to use sound absorbing material in the gap produced by the tapered walls and ceiling to catch and absorb the first reflections from the speakers. The room is relatively small and I want it to remain somewhat “live”. Back wall will include bass traps as well as multiple shelf units. Side walls will also have album and CD shelving. This build will not happen for some time, and I am still researching. I am looking for as much input as possible before construction. All input is appreciated, so let it fly.
Tapered Ceiling
Tapered Walls
Existing Space
Looking to use left rear space in this photo
Schiit Freya+, Krell KAV-250a, R-Pi network streamer, 8Tb NAS, Thorens TD-145 MKIII with Ortofon 2M red, Polk: Monitor-10B, SDA-1A, SDA-SRS
    txcoastal1 Posts: 13,519
    I have a similar design for a future audio room. IMHO "not crazy"
  • crashb4
    crashb4 Posts: 222
    I have been looking for the dispersion pattern off of the baffle of the SRS. That should let me figure out exactly where the taper should stop to collect the first reflection and absorb it. That's the idea anyway.
    Best part with the angled was is cutting room slap
    Good luck, looks like a fun project that will likely be fruitful
    Keep us updated
  • I like your idea with the angled walls! What if you build them but leave them free to be moved i.e. Adjustable angle before securing. Might help with that reflection you spoke of
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • crashb4
    crashb4 Posts: 222
    edited February 2017
    Yeah. I really need to put some thought into resolving the baffle dispersion angle. Most manufacturers publish this information, but I haven't come across it yet. The angle and termination point of the wall and ceiling will be critical.
  • Conradicles
    Conradicles Posts: 6,394
    Very nice room that will be. Have fun!
  • crashb4
    crashb4 Posts: 222
    I may have to make the angle and length adjustable if i can't determine the first reflection points. Thanks for the idea (just have to figure out how to implement it).
  • Joey_V
    Joey_V Posts: 8,603
    txcoastal1 wrote: »
    Is that Mike Lavignes floor plan?
    The bottom one is, I won't be spending that kind of coin
    I drew out the top one.
  • crashb4
    crashb4 Posts: 222
    I've seen photos of that build. It is ridiculously nice.
  • stones89
    stones89 Posts: 229
    crashb4 - great idea! I built out a Rives room 5 years ago and it was the best investment in the hobby I have ever made. One thing you might consider is getting rid of the support poles, called lolly columns. I did not want to take that step but my wife insisted and glad she did. You will have to get a structural engineer to come in to see if you can replace with a beam. Believe it or not it was not that expensive.
    Basis 2200 Signature, Vector 4, Transfiguration Proteus, Allnic H3000, Meridian 200/563, CJ ET5, McIntosh 501's, Thiel CS6, 3.6, Polk SDA SRS 2.3tl, MIT EVO, KS/Wywires PC's
    heiney9 Posts: 25,552
    crashb4 wrote: »
    A noble idea, but will you always use SDA's in that room? Always, forever? What about selling and having an odd shaped room. I just think it's risky to design a room specifically around one thing. What happens when you get different speakers and what was an advantage becomes a disadvantage?
    Just playing a bit of the devils advocate, asking the tough questions.
    Carry on with a very cool project
  • crashb4
    crashb4 Posts: 222
    heiney9 wrote: »
    crashb4 wrote: »
    Canceling first reflections is never a bad thing no matter what speakers are used. Dispersion angles should be relatively close from speaker to speaker and adjustments can be made with little effort once the main structure is in place. I'm not too worried about an odd shaped room. It's certainly better than the bare basement seen in the photos. I certainly do appreciate the input.
  • crashb4
    crashb4 Posts: 222
    stones89 wrote: »
    Good point. I have been struggling with the columns. It doesn't hurt to have someone look. As stated, this project is down the road some, so I have time to consider all input. Much appreciated.
  • polrbehr
    polrbehr Posts: 2,854
    That's a nice space to work with. The furnace tucked in the corner is a nice thing to not have to work around. If you're using the bottom pic, I see that's where your main sewer drain line is, you'll need to have the cleanout accessible. I've never seen the 4" main running along the ceiling like that though.
    Looking down the road, when you're thinking of adding a bathroom, check out Saniflo when you do. They make several products that will save you the hassle (and $$$) of breaking up the floor. I added a 3/4 bath when I finished my basement years ago, and used their SaniPlus macerating toilet; only thing I had to do was secure the bowl with 1/8" anchors into the concrete. It also takes care of a sink and a stall shower, no problems for 8+ years.
  • crashb4
    crashb4 Posts: 222
    That's the plan. A tank behind the wall, up flow toilet and a sink. No concrete demo or trenching. The fixtures are a bit pricey, but when you consider the demo savings, it's a deal.
