Replacement drivers for CS350
I have a driver that's scratchy, from what I have gathered the drivers are MW4850. Would the MW4851 work if magnetic shielding isn't an issue? Are there other alternatives?
Which drivers are in the LS/FX, 4850 or 4851?
Thanks.
Thanks.
I'll pull one later and let you know unless someone beats me to it.
Ok, thanks.
Are the 4851's the same spec as the 4850? -
Bucking magnets is the only difference AFAIK...
Cool, thanks for the help. Good to know I can use either.
