Bang for buck optical cable?
dromunds
Need to pick up an optical cable for connecting TV to HT receiver. New at this and would recommend a good bang for buck cable. Thanks.
These work fine. I have a much more expensive glass toslink cable from PS Audio, but have never been able tell a difference between them.
https://www.amazon.com/AmazonBasics-Digital-Optical-Audio-Toslink/dp/B00NH11H38/ref=sr_1_1?ie=UTF8&qid=1485720226&sr=8-1&keywords=Amazon+basics+toslink -
Thanks much
I had a cheap Toslink and bought a glass one, but there is not much to compare.
I like the idea of the glass one better. I'm not using it currently so... -
search for
GLASS TOSLINK DIGITAL OPTICAL CABLE
on ebay to see it. -
Toslink cables are fairly cheap anyway, I wouldn't be looking to spend big bucks especially for your application. Buy one with good build to it and forget it.HT SYSTEM-
lsi 9's -
Thanks guys!
