Looking for recommendation for good stands for RM series
taser8
I purchased a set of RM2360 speakers several years ago when I was in a house where I was able to mount them to the walls for a good surround setup.
I've moved and am unable to mount the speakers now, so I have to resort to stands. I purchased a set of floor-mounted stands but have found them to be not particularly stable (they tend to fall over forwards) and rather flimsy - someone tossed a light jacket over one of the speakers recently and the mount broke clean off.
I'm looking for recommendations for stands that will be stable and solid; ideally not toooooo expensive but I want something that looks decent and will get the job done.
Thanks!
Thanks!
You can make some from wood and use something like minwax Polyshades to complete it. Home Depot will cut to length for you. There are a lot of options for under $50 if you make it your self.
Me, I would get some 1" X 4' wood dowels, 4 matching small house plant pots and a small bag of quick dry cement. Screw the dowel to the bottom of the pot then fill the pot with cement, let it cure and boom a stand that wont fall very easy.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
