in-wall speakers going into gas fireplace chimney cavity
I will have my front and center speakers in the cavity for my gas fireplace. There's about 12" or more of space around the 6" chimney pipe on all sides. Inside that pipe is the actual 4" chimney exhaust so it doesn't get terribly hot in this cavity like you'd think. I'm installing the LS series speakers (255c-LS and 265-LS) in this wall. There are studs obviously so I could just 1) build a box out of 2x4s between the studs and put a piece of 1/2" plywood on the back and fill the space loosely with polyfil this box would be 4" deep, 2) make this "speaker box" larger by making the box deeper (maybe 6" deep on top of the 4" studs for a total of a 10" deep box) and filling with polyfil, or 3) keep the speakers as is with no box at all.
What would you do?
What would you do?
I wouldn't consider putting speakers in a cavity to begin with. A pic of what your trying to do would help.HT SYSTEM-
lsi 9's -
If your fireplace is installed to code I would not worry about heat. My concern would be vibration transmitting through the chimney and out of the fireplace.
Anything is possible. I remember paulsteve posted a pic of his large SDA 1 speakers wall mounted as shown below:
"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
BlueBirdMusic wrote: »Anything is possible. I remember paulsteve posted a pic of his large SDA 1 speakers wall mounted as shown below:
Is this real?
Or is that one of those, how, not to place speakers! -
I wouldn't consider putting speakers in a (Wall) cavity to begin with. A pic of what your trying to do would help.
Fixed...
Is this real?
Yeah it is a bit nuts, I would not be in that doorway in an earthquake .When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Family Room:LG QNED80 75", Onkyo RZ50 Emotiva XPA3 GEN3 Oppo BDP-93,Sony UBP-X800BM. Main: Polk LsiM 705 Center: Polk LSiM 704CFront High/Rear High In-Ceiling Polk 80F/X RT Surrounds: Polk S15 Sub: SVS SB-17 ULtra
Working Warehouse; Denon AVR-3312ci , Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music
