Center channel comparison?
I currently have the cs10. I found a used cs400 locally. Is it going to be a noticeable difference? I'm using the monitor 60's as my fronts. Is it going to sound weird if the center speakers are bigger than the fronts?
400 is a better center IMO but size isn't the issue. Google timbre matching.
It won't be a perfect sonic match, but it will be far superior to what you have. I have had both matched and mismatched center channels, and if it's primarily for HT I would prefer to have a slightly mismatched, yet superior center channel. If you listen to lots of high-quality multi-channel music then it might bother you more. IHMO...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I'll give it a shot. It's selling for only $45. Thanks for the help.
CS400/CS400i are awesome centers! I have two that I use almost every day.
Jump on it! -
I missed out on the cs400. Any other suggestions to work with the monitor 60's? Would it be stupid to maybe use 2 monitor 40's as my center? My receiver is good down to 2 ohms.
Here: http://www.ebay.com/itm/POLK-AUDIO-CENTER-CHANNEL-SPEAKER-CS-I-40-/222348214146?hash=item33c4fc7f82:g:0zIAAOSw241YVGXx
Or this: http://www.ebay.com/itm/Polk-Audio-CS-400-Center-Channel-Speaker-/361868968320?hash=item5441124180:g:Q~oAAOSwLF1X8wsl
