wall mount speakers recommendation?
Can anyone please recommend me 2 small surrounds that can go with my monitor 60s and CS2? I recently moved and my room is waaaay too small for my monitor 40s for surrounds. Room is basically 10x7 with a larger opening to the left front of the room. The 30s would still probably be way too big. I need small cube type speakers that I can mount to the wall.
Any help is appreciated. Thanks.
  • rpf65
    rpf65 Posts: 2,127
    I'd probably look at the T15's. Not expensive, fairly small, and pretty good sound.
    Don't really need to timbre match the front three, and assuming you want to keep it all Polk.
  • mrloren
    mrloren Posts: 2,487
    Go for the T15 or you could try to find TSX110 or monitor 30's
  • mclebron23
    Thanks guys. I thought the monitor 30s still might be too big. It's only 7ft from wall to wall. Is the t15 smaller than monitor 30s? Thanks.
  • mrloren
    Either would work the T15 is like $70 on Amazon. https://www.amazon.com/Polk-Audio-T15-Bookshelf-Speakers/dp/B002RJLHB8/ref=sr_1_1?ie=UTF8&qid=1484410882&sr=8-1&keywords=polk+t15
    Fry's and even Best Buy has had these on sale for like $50.
    For my bed room surround speakers I am using an older one in the R15, looks like the same speaker and works great, 1/3 the size of my RTi4
  • [Deleted User]
    this is what I did;
  • mclebron23
    mclebron23 Posts: 20
    edited January 2017
    Thanks guys.
