Filtered or unfiltered? PSW-350
barney69
Hey guys,
I've had my PSW350 for a couple weeks now and I was wondering if the sub would sound better using the filtered or unfiltered inputs on it.
I have a H/K AVR210 receiver and in the receiver I'm not sure if it already filters the preout of the sub out. So my question is does anyone have similar equipement? And does anybody know how to set this one up properly?
Post edited by barney69 on
there are 2 ways of setting up this sub. you decide which is better for you.
if your receiver has a sub out, then 9 times out of 10 its filtered. so connecting it to the filtered line in ports on the back of the sub isnt ideal, the 2 filters will have a negative effect. so place your interconnect to the LFE line in unfiltered terminal, thats why its there. and set your receiver to SUB: yes.
Ok to avoid filtering all together set you receiver to sub: no and fronts: large. connect the sub to the A speaker channels both left and right with speaker wire via speaker level input. connect your front speakers to the sub via speaker level out.
gooed luck -
Hey thanks man, I'll try that as soon as I get home and I'll post a reply on how it goes cuz right now I'm about to go to my French lecture.
Peace and thanks.
