How Hard Is It To Replace Grill Cloth?
I plan to spruce-up my SRTs and want to repair some of the broken posts and replace the cloth on the grills. It looks like it would be fairly easy to replace cloth on a nice flat grill like a bookshelf speaker has but these SRT grills are pretty-long with a triangular profile.
How difficult do you think they would be to recover? This picture below shows the shape of the SRT grills.
  • polrbehr
    polrbehr Posts: 2,861
    Is there any way to remove the existing cloth without damaging it? You could then use that as a template.
    Shouldn't be too bad though, I would just order enough to overlap, and plan on using a razor blade to make cuts (like they do when they cover a pool table with new felt).
    pitdogg2 Posts: 27,596
    I've done the wooden that are stapled but the plastic bezels that seem to be heat glued scare me.
  • lawdogg
    lawdogg Posts: 469
    You can use rubber cement. Put it on the back of the frame where the cloth will go and let it dry. Then put on the cloth and use a hot iron to re-activate the glue and it'll hold great. I've done this with a couple pairs of old JBLs as it seems to be the best practice in that community.
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • Gatecrasher
    Gatecrasher Posts: 1,538
    lawdogg wrote: »
    Sounds kind of daunting. Anyone know of any professional outfits that can do it?
  • Dennis Gardner
    You have to determine whether the cloth is tacked to the whole plastic grill frame or just along the sides. Either way, I would use spray adhesive to attach them. 3m 77 is good stuff.
    advantagesgs.com/3M-Super-77-Multipurpose-Adhesive-24-oz.html?source=googleps&gclid=CPyQ_sLaq9ECFQgJaQod_8cKRw
    good stuff when I did my SDA2a frames a little on both cloth and frame let set for 30 or so seconds apply. I wasn't sure this would work on plastic, but I've done many a headliners with it. Once it bonds there is usually no moving it.
