5 Jr & Marantz 2230
New here but not to Polk. New to vintage as well but have been researching.
This sounds like a perfect pairing. I have a small studio apartment and listen mostly to jazz. The Marantz was just cleaned and is for sale at a local and reputable hi-fi shop. The speakers are on eBay - the one woofer/no radiator model. I'm just looking for a simple setup with a warm sound.
Any opinions, warnings, etc. about what I'm getting into are appreciated.
    msg Posts: 10,550
    How much space do you have to work with?
    Are you planning to use stands for the speakers?
    If not how do you plan to set the stuff up?
    I haven't heard the 5JR, only JR+, with the passive bass radiator.
    I find the 5JR+ a bit thin in the lows. Maybe some Monitor 5's or 7's if you want something a little fuller sounding? Though I think I read about a guy who rebuilt the crossovers in his 5JR+ and liked them.
    xschop Posts: 5,668
    Simple and warm is what you'll have. I've listened to a 2238 run a set of 5Jr and a set of EPI 100 separately and they are both beautiful sounding setups.
  • kevinko
    kevinko Posts: 165
    Thanks xschop.
    msg - It's basically a large bedroom - with nearby neighbors - so I try to be reasonably quiet. The fuller the bass the more annoyed the neighbors.
    Stands are a little unsightly. I might have to improvise there - album crates maybe? It would give me somewhere to put a new record collection....
  • boston1450
    boston1450 Posts: 7,758
    Years ago I had a pair of 5a's with Peerless tweeters hooked to a small Sansui 20wpc (G2000) I think & it sounded vgood. I sure do miss that set up & how it sounded. I put em on milk crates I snagged from the local corner store :)
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    Forgot to mention = Welcome to the forum Kevin
    Randy-Maine
    by David WMG
    F1nut Posts: 52,173
    Good stands are not unsightly and really are a requirement to get the best out of those speakers. You want the kind that can be mass loaded.
  • kevinko
    kevinko Posts: 165
    thanks boston - milk crates are always a go-to
    useful advice F1 - I just looked up "mass loaded" stands - I have a lot to learn...
    xschop Posts: 5,668
    When all else fails, maybe put them on bookshelves.
