Sanus Foundations Steel Series SF26B Stands
teamjhertz
teamjhertz Posts: 363
edited January 2017 in Speakers
I went ahead and purchased a set of SF26 Sanus stands for my LSiM703's. I decided to mass load them with sand. The sand was bone dry and added about 7lbs per stand. I was expecting more mass but I guess the pillars are not that large. The stands end up weighing 22lbs each filled for reference.
I did decide to open up one of the smaller holes in the pillar to a 3/8" hole. This made it much easier to fill them.
The pillars had a real high pitch ring to them before filling and are ring free after.
Below is a picture for reference
    F1nut Posts: 52,136
    Lead shot.
  • teamjhertz
    edited January 2017
    Thanks for the tip
    I thought about it but have three little ones.
    And did not want to risk anything even though I am sure the risk is low
    F1nut Posts: 52,136
    Gotcha. You could use steel shot in that case. Mix with sand to fill the small gaps between the shot......nice!
  • Dabutcher
    Dabutcher Posts: 2,614
    I bought the same stands for my new 703's . Thanks for the help. Peace. D
  • I will check into some steel shot
  • adb3da
    adb3da Posts: 507
    Do you have a pic of how they look on the stands? I am considering these for my 703s as well.
  • stangman67
    stangman67 Posts: 2,330
    A great alternative for 703's are these transdeco stands https://www.amazon.com/TransDeco-TD24B-Speaker-Stands-24-Inch/dp/B00CQCIRTG
    Real solid stands that are incredibly stable with the 703's on top. Here are mine
    msg Posts: 10,528
    Those TD stands look pretty nice.
    Do the columns ring hollow at all if you tap on them? Are they mass-loadable?
  • stangman67
    If you really rap on them, they give a bit of a hollow ring but they are fairly solid. Yes mass loadable, there is wire management holes in the pillars but you could use sand or lead shot in baggies or plug the holes
  • Dabutcher
    Mine are the Sanus SF28 inch for $30 off CL brand new in box. Need 26" to be completely honest. Very sturdy Velcro ed to base. Peace Dw5k1b6xbzgmi.jpg
    msg Posts: 10,528
    nice setups!
  • teamjhertz
    edited January 2017
    Here is the setup so far still need new speaker cables and maybe a 706 instead of a 704jqtf0g0gjht7.jpg
  • stangman67
    Toe those babies in a little bit!
  • Will do
    I have not powered anything up yet lol
  • rooftop59
    rooftop59 Posts: 8,120
    FYI I have a brand new pair of these for sale in the flea market
    Game Room 5.1.4:
    Bedroom 2.1
