7.1 distance
What's the ideal distance behind seating for the surround backs in a7.1 set up? Is 10 feet ish too far? It's either that or like 2 feet
  • rpf65
    rpf65 Posts: 2,127
    Depends on the speakers, and how high your placing them.
  • Emlyn
    Emlyn Posts: 4,920
    Ten feet should be fine and preferable to the speakers being too close. Auto setup in the receiver can control for timing and distance differences at the seating area.
  • bigmike66
    bigmike66 Posts: 23
    edited January 2017
    Speakers are polk rt2000p fronts, cs350 center, ls/fx side surrounds, and rt3 back surrounds, svs pb2000 sub, all run off denon 3310ci. I can either mount them on the front of the bar, top of the speaker will be 4 feet of ground. Or I can mount on back wall, about 8-10 feet behind couch(haven't built that wall yet) and can mount whatever height. But they will be behind the bar
  • rpf65
    rpf65 Posts: 2,127
    Would go with on the bar.
